Hello
the MIDI fastlane cause kernel panic under osx 1.4.8 with logic 7
i have use the drivers 1.3.4 very unestables crash a every moment
some suggestion?
greetings
Fastlane drivers cause kernel panic in imac coreduo
- Dwetmaster
Hi,
this it is report error
panic(cpu 1 caller 0x001A3135): Unresolved kernel trap (CPU 1, Type 14=page fault), registers:
CR0: 0x8001003b, CR2: 0x83c8e3df, CR3: 0x00ddb000, CR4: 0x000006e0
EAX: 0x03c5a000, EBX: 0x0081bedc, ECX: 0x00397a6e, EDX: 0x03a26800
CR2: 0x83c8e3df, EBP: 0x1cb2bc98, ESI: 0x03a26914, EDI: 0x03e22cc0
EFL: 0x00010246, EIP: 0x036ae28b, CS: 0x00000008, DS: 0x00000010
Backtrace, Format - Frame : Return Address (4 potential args on stack)
0x1cb2ba88 : 0x128d1f (0x3c9540 0x1cb2baac 0x131df4 0x0)
0x1cb2bac8 : 0x1a3135 (0x3cf1f4 0x1 0xe 0x3cea24)
0x1cb2bbd8 : 0x19a8d4 (0x1cb2bbe4 0xe 0x48 0x3ef0010)
0x1cb2bc98 : 0x7d6907 (0x3a26800 0x81bedc 0x0 0x1)
0x1cb2bce8 : 0x7d7559 (0x3629300 0x1 0x81bedc 0x0)
0x1cb2bd18 : 0x3b0844 (0x3a7de00 0x3e22cb4 0x41f9594 0x11)
0x1cb2bd68 : 0x18a187 (0x3a7de00 0x4 0x3e22cb4 0x11)
0x1cb2bdb8 : 0x12b4da (0x3e22c8c 0x41f956c 0x0 0x0)
0x1cb2bdf8 : 0x124b2b (0x3e22c00 0x0 0x40 0x1cb2bedc)
0x1cb2bf08 : 0x1955a1 (0x1cb2bf44 0x0 0x0 0x0)
0x1cb2bfc8 : 0x19ad4e (0x30a639c 0x0 0x19d0b5 0x392cc98) No mapping exists for frame pointer
Backtrace terminated-invalid frame pointer 0xb0385928
Kernel loadable modules in backtrace (with dependencies):
com.motu.driver.USBMidiKext(1.3.3)@0x7d5000
dependency: com.apple.iokit.IOUSBFamily(2.6.1)@0x515000
Kernel version:
Darwin Kernel Version 8.8.1: Mon Sep 25 19:42:00 PDT 2006; root:xnu-792.13.8.obj~1/RELEASE_I386
Model: iMac4,1, BootROM IM41.0055.B03, 2 processors, Intel Core Duo, 2 GHz, 1.5 GB
Graphics: ATI Radeon X1600, ATY,RadeonX1600, PCIe, 128 MB
Memory Module: BANK 0/DIMM0, 512 MB, DDR2 SDRAM, 667 MHz
Memory Module: BANK 1/DIMM1, 1 GB, DDR2 SDRAM, 667 MHz
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x89), 4.80.46.0
Bluetooth: Version 1.7.9f12, 2 service, 1 devices, 1 incoming serial ports
Network Service: Ethernet incorporada, Ethernet, en0
Serial ATA Device: WDC WD2500JS-40NGB2, 232.89 GB
Parallel ATA Device: MATSHITADVD-R UJ-846
USB Device: Built-in iSight, Micron, Up to 480 Mb/sec, 500 mA
USB Device: Hub in Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 500 mA
USB Device: USB Device, Up to 1.5 Mb/sec, 100 mA
USB Device: FastLane, Up to 12 Mb/sec, 100 mA
USB Device: Apple Pro Keyboard, Mitsumi Electric, Up to 12 Mb/sec, 250 mA
USB Device: AKAI Z4/8 Sampler, AKAI professional M.I. Corp., Up to 12 Mb/sec, 500 mA
USB Device: Bluetooth HCI, Up to 12 Mb/sec, 500 mA
USB Device: IR Receiver, Apple Computer, Inc., Up to 12 Mb/sec, 500 mA
Kernel version:
