I have installed Motu BPM on my laptop
updated drivers, it sees the audio drivers but not the Korg Nano pad I installed.
i have updated drivers on the nano
nothing
Can anyone help at all?
Rob
Cant See MIDI Device
Moderator: ssp
Re: Cant See MIDI Device
If you've installed the nano drivers,you must also install the nano's MIDI drivers,you have to manually do this though...check the paper manual or read the .pdf on the how to.. Once you do that,they will show up..
thanks for help did this already and downloaded http://www.korg.co.uk/downloads/driver/dl_driver.asp
still to no avail.
any further suggestions?
Rob
still to no avail.
Rob
Yes,those are the right drivers,but have you manually installed the MIDI drivers? They are separate from the regular installer,you have to install them a bit different,by going into,program files,KORG,install MIDI etc,if your on xp,you don't say which OS your on,Perhaps it's a bit different if your on a mac,but you posted in windows forum,so I assumed your on Xp,anyhow check the manual..on the instructions,trust me,they have to be installed a certain way..eventstudioz wrote:thanks for help did this already and downloaded http://www.korg.co.uk/downloads/driver/dl_driver.asp
still to no avail.
Rob
ah no thanks for heads up
sorted
