Some quick questions of on best sample HD config ...
I have 2 internal Sata drives (250 GB) in my G5 - the second I use purely for BFD and Kontakt samples. As it is now full I am now going to start using a Lacie 300GB d2 external HD as another sample drive. I also use another Lacie d2 for DP projects via FW 800.
Question 1 - is it better to daisy chain project drive and sample drive on the same FW800 or use one on FW800 and one on FW400?
Question 2 - for a sample only HD what is the best format to use? Also, is partitioning a good idea? ie I was thinking one small partition area which I could use for my own samples (ie ideas that may stay on drive or not) and so only this partition would get fragmented. The main one would stay clean...
Question 3 - I also need to backup a whole load of old samples and projects (over 200GB). I usually use DVD+ for sample backup/storage - what about dual layer DVD's? can a G5 superdrive even write dual layer DVD's? - I noticed my toast certainly has an option for it. But maybe dual layer is more prone to errors and scratches....? (I find normanl DVD's bad enough)
Question 4 - was thinking of using my old G4 to do the all the DVD writing - it's not a super drive, just a DVD read/ write. Do you think the G4 is going to be more prone to errors (when writing about 50 DVD's) just because it's older or is it likely to make no odds?
Ext HD config and DVD backup questions
- Spikey Horse
