Show all automation lanes?
toodamnhip
Post by toodamnhip »
Is there a single command or pull down menu command to show ALL automation lanes at once, and after, hide them again? This question means, in a mix with multi parameter plug ins, I am looking for ONE command to show many lanes of automation below the main track. Manually doing this is too slow to be practical. Thanks
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
ronjams
Re: Show all automation lanes?
Post by ronjams »
Try using the filter command from this window you can hide or show a lot of different data types using the keyboard shortcut (command f).
Mac Studio M1 Max DIGITAL PERFORMER1248/8pre ESFalcon/kontakt/Unify & A LOT MORE GEAR
CharlzS
Post by CharlzS »
Shift= may be what you're looking for. Select track(s) then shift=. All the lanes with data will open below the track. Shift= again and all close. If you want to see them all on one lane below, don't know if that's possible. If you want to see them all on the track itself, uncheck menu View --> Only show active edit type.
