Why can't I just draw controllers (e.g. volume) into the sequence window and have MSI respond? If I do a "MIDI learn" for volume from a controller on my keyboard, it works with that controller only.
My problem: only have pitch bend and modulator wheels on my keyboard. I want volume for an MSI part mapped to controller 7 (the normal volume controller) - but if I simply scroll to cc7 in the "MIDI learn" window, MSI doesn't respond to controller changes I enter in the sequencer window. However, if I "MIDI learn" my actual modulation wheel for the volume knob of the MSI part, then it responds to modulator controller (1) I draw in the sequencer window.
Anybody get this? Any help? Thanks in advance!
"Penciling in" controllors in DP4.6
update: how to use controllers in DP
Thanks for the response, joelmusic.
I did find out that MSi responds to controllers drawn in the "Sequence Editor" window. I don't know why it wouldn't work in the grapic editor, unless I was doing something wrong. But if you do the correct enables, you can control individual part volume and a couple other parameters.
