Stops on "Looking for Network".
Allowed through Firewall.
Using USB 3 or 2 makes no difference.
Everything disconnected.
I keep cycling the unit with no success.
Please can someone HELP???
Installed Driver 4.0.9.2009
Current Firmware 1.3.5+184 want to update to Firmware 1.4.0+90954
Motu 8preES won't update on Win 11
- Primary DAW OS: Windows
Re: Motu 8preES won't update on Win 11
I recently updated this way:
If that doesn't work, I would go to motu for support -- they are quite responsive.
- Disconnect the 828es from USB/Thunderbolt
- Connect it directly to your computer with Ethernet
- Power the 828es off
- Power it back on while holding the MENU knob - it will go into update mode
- Wait a few moments and an IP address will appaer on the screen
- Type the IP Address into a web browser and you'll be brought to the update page
- Select the (already downloaded) firmware file
Robert W. Anderson
MOTU 828es (had an Ultralite original, mk3, and AVB)
Helix & Clarett+Octopre
Presonus S1 (formerly Sonar)
PreSonus MonitorStation
Event Biamplified 20/20
Primarily play PRS, Gibson Les Paul & EC-30.
Thank you, worked as you described.
Great, thank you for confirming!
Robert W. Anderson
