If you're using DP 11.31 with Console 1 DO NOT UPGRADE TO SONOMA!!
Posted: Fri Mar 08, 2024 12:38 am
Let me try to save you from my own fate. If you're using Console 1 with DP 11.31 and you're on Ventura, do NOT upgrade to Sonoma. There's a weird issue that I and other users are experiencing where the RTA in the Console 1 On Screen Display app will start to get jumpy. It doesn't stop there. Controls will be sluggish. When you turn a knob on the hardware control surface (in my case I have the older Mk II unit) the knob on screen won't respond smoothly and appear stuck then jump to the next value. It's not just graphical... the audio change will be sluggish as well.
Now from what I and other users have ascertained the only workaround is to have ONLY THE TRACK OVERVIEW OPEN. No other windows can be open. The Console 1 will behave normally. You can open some of the other window with minimal impact... probably ones like Chunks, Big Counter, etc. are okay. The Sequence Editor has the worst impact of all. If the Sequence Editor window is open Console 1 will be sluggish. You can close it, and re-open it and then Console 1 will appear to be normal again, then gradually the RTA will start becoming less smooth and in a matter of maybe 30 seconds or so you'll be sluggish again until you close the Sequence Editor.
Now this is apparently due to some sort of graphic issue that was introduce in Sonoma. If you remember from DP 11.31's release notes there was a workaround described in there that alluded to this. Apparently it wasn't enough to fix this issue. And to make things more annoying, I can tell you that I also own Pro Tools 2024.3, Logic 10.8.1 and Cubase 13.0.20 and NONE OF THEM have this problem with Console 1. This is unique to DP.
I even updated to Sonoma 14.4 tonight hoping maybe Apple slipped in a fix for this and it's no go. Which means there's likely going to not be another macOS update for some time. So if this is a macOS bug and there's nothing MOTU or Softube can do, well then if you're on DP 11.31 and Sonoma like me and want to use Console 1, it probably means making a Window Set with only the Track Overview open and then invoking it any time you want to work with Console 1 and then invoking your normal one when you're done. I have a three monitor setup, so as you might imagine is a royal pain in the patootie.
Anyway.... you have been warned. Ugh...
