Select & Edit all volume automation at once
dazzjazz
Post by dazzjazz »
Hi
Select & Edit all volume automation at once please?
I've tried doing it in the Sequence window by switching all tracks view to Volume, then Command-A and drag but it only move the volume for the individual track I grab.
Darren
iMac 27" 2013 24 GB RAM
OSX Catalina. Focusrite Clarett 8Pre. Heritage Audio HA73.
DP10.
Yamaha CP4. 1961 Hammond A100. Too many Leslies.
Darren Heinrich
BMus (Hons) Jazz Piano
PhD Jazz Organ Improvisation
http://www.dazzjazz.com/
CharlzS
Re: Select & Edit all volume automation at once
Post by CharlzS »
Create a group or use temporary grouping in the SE.
Tidwells@aol.com
Post by Tidwells@aol.com »
Hey, Darren! I'm thinking that you can use the "change continuous controller" function which I believe is in the "region" menu. (I don't have DP available right now to confirm that). I know I've used it to add to or subtract from a series of volume automation points in a region on multiple tracks simultaneously.
Doug
dazzjazz
Post by dazzjazz »
Thanks all, I figured out to double-tap ‘W’ then I can grab all the volume lines. Works a treat.
DP10.
Darren Heinrich
