Consolidate edited tracks
Hey all got a question here. In Protools after editing a track with cuts and fades etc. I can consolidate the track to be a complete track without the edits showing. Not heal separation. In DP to I have to bnc the track to do that or is there a consolidate feature? Thanks !
2009 8 Core 5.1, 2012 6 Core MacPro,s , (32 gigs Ram) Mojave 14.6, Radeon 570, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT ,DP11 , PT 2022.12, Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 10, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
Re: Consolidate edited tracks
Isn’t that more or less what Freeze Selected Tracks does? The clunkier approach would be to Bounce, keep the originals, but mute or disable them and hide it until you need to do more edits.
What about Merge Soundbites (in the Audio menu). Doesn't include automation but does a PT style consolidate. You can select the track or select multiple soundbites in the track.
Thats it ! Thank you Sir !!!
Handy to make a Duplicate Take first, so if you have to revisit edits, you can revert.
Merge also writes pitch and soundbite volume info into the file, so pitch edits are incorporated in the track and the entire new merged soundbite (not the fader) is set to volume of Zero.
Very useful information, thank you!HCMarkus wrote: ↑Sun Dec 03, 2023 2:04 pmHandy to make a Duplicate Take first, so if you have to revisit edits, you can revert.
http://www.bfdmusic.com
Mac Studio Ultra, 64 gigs RAM, OSX 12.7.3, DP 11.3, UAD2 thunderbolt satellite octo, Apogee Symphony IO MK2 TB
