896mk3 Inputs 1 and 2 won't mute (Resolved)
Posted: Sat Oct 28, 2023 11:24 am
This is probably a ridiculously easy question to answer.
No matter what combination I have CueMix FX in, I am continuously hearing signal into inputs 1 and 2. If I have both channels muted, I am still hearing input 1 on the left channel and input 2 on the right.
I have these channels muted on all eight busses.
If I have them unmuted, I see the signal in Analog 1 and 2, Mix 1 and Main Output.
If I have them muted, I see the signal in Analog 1 and 2, nothing in Mix 1 and signals at Main Output.
Even if I assign all busses' outputs to None, I still hear inputs 1 and 2 through the Main Outputs and see them in CueMix FX on Analog 1 and 2 and Main Outputs meters.
I have a good handle on CueMix FX, so, it doesn't seem to be any usual things to try. I have all of the other functions off (I don't have any exotic Stereo modes selected, I do have both channels' pans set to zero, I don't have overload protection on, Talkback is not enabled, EQ is off, Dynamics are off, Reverb is off).
I have MOTU Audio Setup set to:
Default Stereo Input: set to Inputs 1 and 2 (no matter what I change this to, it does not solve the problem).
Default Stereo Output: set to Main outputs.
Phones Assign: Set to Main outputs
Return Assign: Set to AES/EBU 1-2
No matter what I set these to, the problem is still there.
This is a Black Lion modded unit. Is it possible they accidentally or on purpose jumped something that's causing input 1 and 2 to always be heard through Main bus (Main outputs and headphones)?
