Hardware Monitoring Mix on M2
Posted: Mon Aug 21, 2023 1:04 am
by Reeper_Lumish
The M4 has a dial to adjust the hardware monitoring mix between the PC and microphone, but the M2 doesn't have that dial. Does that mean the M2 can't mix the hardware monitoring level, or does it just have to be done in software?
Re: Hardware Monitoring Mix on M2
Posted: Mon Aug 21, 2023 10:03 am
by mikehalloran
There is no mixer in the M2/4/6, only the options to monitor your Out (to your DAW) are either mono or stereo with 1/3/5 panned L and 2/4/6 panned R.
Since there’s no Out/In blend/balance/mix knob on the M2, you use the Monitor switch to set up the basics. Normally, your Out to your DAW is mono while tracking and your In from the DAW will be set up there, either Stereo or Mono depending on how you are monitoring your tracks.
https://cdn-data.motu.com/manuals/usb- ... _Guide.pdf
The RTL (round trip latency) over USB 2 is so low that it is inaudible for most users if your buffer is set low enough.
Posted: Mon Aug 21, 2023 2:01 pm
by Reeper_Lumish
So the monitor button on the M2 enables hardware monitoring. While hardware monitoring I can hear my microphone as well as my computer system sounds. Is there a way to adjust how much of each one I am hearing when doing this? I know the M4 and M6 have dials that do this.
Posted: Mon Aug 21, 2023 7:43 pm
by mikehalloran
So the monitor button on the M2 enables hardware monitoring. While hardware monitoring I can hear my microphone as well as my computer system sounds..
Page 7 of the manual that I linked.
Not in the M2. You set that up in your DAW on your computer. Not hard at all.
Correct. It's more convenient.
Posted: Tue Aug 22, 2023 4:11 am
by HCMarkus
Set up DP so overall playback level is controlled by a single fader. I do this with Auxes as follows:
In Bundles, set up the following Aux Buses: Master, Record and Monitor.
Add two Aux Tracks in DP: Master and Monitor.
Add an Audio Track in DP: Mix
All Audio and VI Outputs in DP are routed to Master Bus > Master Aux Track in DP Mixer.
Insert Mastering plugins here when mixing if desired. Do Not Insert Mastering Plugins with Look Ahead until you are done recording VIs; they will cause latency,
Master Aux Track Output > Record Bus
Record Bus > Mix Audio Track (to record mixes)
Record Bus > Monitor Bus (Input to Monitor Aux Track in DP mixer) which is routed to Interface (Speakers/Headhpones).
Set your Mic/Instrument input gain on your Interface to proper input level for recording and route to the desired Audio Track Input in DP (Input monitoring OFF in DP). generally, I suggest recording with peaks between -12 and -6dB.
Set your Speaker/Headphone Level using the output gain control on your interface so you are hearing your Mic/Instrument at a comfortable level..
Set your DP playback output level using the Monitor Track fader in DP to blend as desired with your Mic/Instrument.
