select multiple Soundbite Clips - RESOLVED
I have 9 audio tracks. I have Soundbites I've edited, and want to highlight / select them as you see here in blue. I can Click one track, and then Shift-Click the other eight Clips to highlight all of them, but is there a way to drag over them to select them?
I've learned I can select multiple clips by Control-Option dragging over the ENDS (head or tail) of multiple Clips, but I haven't found a way to do it when they're overlapping other clips as you see here.
- Screen Shot 2023-07-23 at 6.34.21 PM.png (271.52 KiB) Viewed 496 times
recording: Mac Mini 2018 - 32GB RAM - 3.2 GHz 6-Core Intel Core i7 - two Focusrite Scarlett 18i20 - OS 12.7.4 - DP 11.23
mixing: MacPro7,1 - 256GB RAM - 2.7 GHz 24-Core Intel Xeon W - Focusrite Scarlett Solo - OS 12.7.4 - DP 11.23
Both computers: Kontakt Komplete 13 VIs and effects. Effects: FabFilter, Sonnox Oxford, SSL, PSP, UA, iZotope. VIs: Cherry Audio, AIR Tech, GForce, AAS, East-West, Garritan, Best Service, Kilohearts, Brainworx, UA
- pencilina
Re: select multiple Soundbite Clips
You can create a group and/or use the lasso tool.
When I do that, it selects the selection, plus all the layers below. The blue Soundbites in my attachment were merged on top of existing tracks. I want to select the Front layers so I can slip and slide them. See attachment. I lassoed from the empty track on the bottom over the Soundbites in the center, and you can see it selected the underlying Soundbites as well.
Plus, I have to enable an empty track with the Track Selector just to be able to drag a lasso/cursor across the tracks I want to select. Otherwise, it drags the Soundbite if I start dragging on a Soundbyte.
What am I missing?
What am I missing?
- Screen Shot 2023-07-24 at 12.06.58 AM.png (77.27 KiB) Viewed 465 times
You can also enable just the soundbites in the view filter before selecting.
- pencilina
I'm not sure what's going on with your lassoing. Try creating a group and selecting one of the soundbites. You should be able to slide the top layer wherever you want.
OK, I see what you mean now. I already had those nine tracks assigned to a Group, but I had "Selection" disabled. Now that I've enabled "Selection," when I click on one part of the overlayed Soundbites, they all highlight as I want.
I don't always want to highlight all tracks. Every now and then, I will select, say, part of a snare or tom bite to Split so that I can increase the volume of one wimpy hit. I can Disable the Group when I want to do that.
Thank you!
Cool! Glad that's sorted out. I'll mark this RESOLVED.
- pencilina
Re: select multiple Soundbite Clips - RESOLVED
Cool! I’d suggest getting to know the enable/disable group shortcut it’ll be your best friend, editing audio. Also, notice the custom group options. You can tailor groups to different tasks. EG, you might want to just have a group for editing, and not affecting automation or record enabling…
