MIDI Takes via cycle record yet?
- dazzjazz
Okay, it's been 3 years since I last asked about this, and I'm still on DP10.13 - I doubt my 10 year old iMac would handle an update (?).
I would LOVE to be able to create multiple takes of MIDI via cycle record - is this possible yet?
Darren
Darren
iMac 27" 2013 24 GB RAM
OSX Catalina. Focusrite Clarett 8Pre. Heritage Audio HA73.
DP10.
Yamaha CP4. 1961 Hammond A100. Too many Leslies.
Darren Heinrich
BMus (Hons) Jazz Piano
PhD Jazz Organ Improvisation
http://www.dazzjazz.com/
DP10.
Darren Heinrich
Re: MIDI Takes via cycle record yet?
This is just an obviously great feature to have.
I suppose there's a small question of how to integrate it with the current UI. I suppose they could do a MIDI version of POLAR (I'm sure that's been requested before). Alternatively, a plugin could perhaps exist or be made that could do such a thing, where takes within the plug could be dragged & dropped back into the tracks window. But obviously what MOTU could do could be well-integrated.
- dazzjazz
I just spoke to MOTU. MIDI cycle record is not available yet. Said they’d bump it as a feature request.
A few more users petition them would be helpful, I guess.
DP10.
Darren Heinrich
DP10.
Darren Heinrich
Noted.
- pencilina
I've requested this multiple times since audio takes were introduced decades ago. I find it bothersome and disappointing that MOTU has yet to implement it. All that would need to happen is that MIDI tracks would behave the same way as audio tracks do, each loop cycle during recording creates a new take.
- dazzjazz
I was wondering if there’s an issue with say, note off information getting chopped off and glitchy?
Shouldn’t be the case - they seem to have that sorted.
DP10.
Darren Heinrich
DP10.
Darren Heinrich
There are some workarounds, and there might be some more clever ones possible.
Perhaps, using some combination of available COMMANDS, a bit of up-front prep, (e.g., creating a multi MIDI tracks instead of takes), and possibly using MIDI to trigger some macro utility, one could streamline the process of cueing up and recording subsequent takes.
Not sure what this would look like. Could DP send MIDI to a macro program like Keyboard Maestro? Then KM could send some MIDI to trigger commands back in DP?
I suppose you could set up a folder of MIDI tracks, put the first into record mode, and have a MIDI key command in the Commands window that issued a Down Arrow to move record status to the next track, and press that to start a new take. Or we could advocate for MOTU to implement a command to put record into Overwrite, Merge, or Takes mode. Doesn’t even really need to be takes. Layers would do.
I think this could be an elegant solution-- Doesn't even take up more screen real estate. Click on the mode button to toggle between those three modes, done. Bob's your uncle.
When in takes mode, and not in Memory Cycle, it would just always start a new recording in a new take. If Memory Cycle is on, it will automatically create a new take with each new cycle. DP will have to manage the note-offs amongst the takes if they overlap-- but that could just follow a rule of any note on in the cycle range stays on that take. Or there could be a little preference "notes XX ticks before cycle end push to next take". But one could just deal with that manually-- or put enough pre-roll & post-roll.
Are there logistical issues with this? Probably.
More likely priority issues, catching up with Logic and Ableton with articulation and clips, and things like that. Not stuff I care about, but MOTU seems to be going down that path.
Not things I care about either. I’m more annoyed by a latency compensation bug with the hardware insert.bayswater wrote:More likely priority issues, catching up with Logic and Ableton with articulation and clips, and things like that. Not stuff I care about, but MOTU seems to be going down that path.
Perhaps a little OT, but whenever some little feature thing like this comes up, I think, "Yea, it'll never happen." That inherent pessimism I have about these kinds of features is a little discouraging.
- dazzjazz
Sure Stubb, like I said, it's gobsmacking it doesn't exist already.
DP10.
Darren Heinrich
DP10.
Darren Heinrich
- pencilina
My sentiments exactly.stubbsonic wrote: ↑Fri Jul 21, 2023 3:32 pm Perhaps a little OT, but whenever some little feature thing like this comes up, I think, "Yea, it'll never happen." That inherent pessimism I have about these kinds of features is a little discouraging.
I've been asking MOTU for a MIDI Plugin CC Lag Processor (Attack/Release Envelop) for years.
Cue obligatory R. Stones... followed by Gloria Gaynor.
