Antares Harmony Engine Evo
Does anyone have experience using Antares Harmony Engine with DP? I just purchased it and am trying to load it in, but every time I scan it, it says "Failed." How do I work around this issue?
2019 MacBook Pro, MacOS Monterey 12.6.3, 16GB RAM, 1TB HD, DP 11.11
Re: Antares Harmony Engine Evo
Not enough information. What version of DP? What MacOS? Have you installed the latest CodeMeter Run Time?
DP 11 on MacOS Monterey. I don't know about CodeMeter - where is it and how do I install it?mikehalloran wrote: ↑Sun Jun 04, 2023 7:44 amNot enough information. What version of DP? What MacOS? Have you installed the latest CodeMeter Run Time?
Antares uses CodeMeter from Wibu for licensing. You must install a CodeMeter run time to activate your license. The instructions on Antares site are a bit confusing but they do work.elarue wrote: ↑Sun Jun 04, 2023 12:17 pmDP 11 on MacOS Monterey. I don't know about CodeMeter - where is it and how do I install it?mikehalloran wrote: ↑Sun Jun 04, 2023 7:44 amNot enough information. What version of DP? What MacOS? Have you installed the latest CodeMeter Run Time?
Antares does not always have the latest version on their site — this has caused me major grief in the past. Once you are properly licensed, you can download and install the latest version here:
https://www.wibu.com/us/support/user/do ... tware.html
Okay, I found Codemeter through a Google search, but I wasn't sure how it worked, so I didn't install right away. Once I saw what it was, I thought maybe it was something that DP used. I had activated my license through Auto-Tune Central thinking that was sufficient, but maybe it wasn't. I'll install the latest Codemeter and see if that does the trick.mikehalloran wrote: ↑Tue Jun 06, 2023 10:51 amAntares uses CodeMeter from Wibu for licensing. You must install a CodeMeter run time to activate your license. The instructions on Antares site are a bit confusing but they do work.elarue wrote: ↑Sun Jun 04, 2023 12:17 pmDP 11 on MacOS Monterey. I don't know about CodeMeter - where is it and how do I install it?mikehalloran wrote: ↑Sun Jun 04, 2023 7:44 am
Okay, installing the latest Codemeter did not do the trick. Not sure if I need to do a clean install of Harmony Engine now or if there's still another lingering issue.elarue wrote: ↑Tue Jun 06, 2023 11:14 amOkay, I found Codemeter through a Google search, but I wasn't sure how it worked, so I didn't install right away. Once I saw what it was, I thought maybe it was something that DP used. I had activated my license through Auto-Tune Central thinking that was sufficient, but maybe it wasn't. I'll install the latest Codemeter and see if that does the trick.mikehalloran wrote: ↑Tue Jun 06, 2023 10:51 amAntares uses CodeMeter from Wibu for licensing. You must install a CodeMeter run time to activate your license. The instructions on Antares site are a bit confusing but they do work.
Other than referring you to Antares, I don't know. It does work for my in DP 11 over Ventura. They used to use iLok but I think they switched back in 2017 otr so.
https://www.antarestech.com/getting-started
Shot in the dark, but try launching DP in Rosetta and then rescan the plugin. Sometimes that works.
Okay, dumb question. What do you mean by "launch DP in Rosetta?"James Steele wrote: ↑Tue Jun 06, 2023 3:38 pmShot in the dark, but try launching DP in Rosetta and then rescan the plugin. Sometimes that works.
Yeah, I submitted a ticket with them, and all they recommended was to do a clean install. I told them that didn't work, and then, crickets.mikehalloran wrote: ↑Tue Jun 06, 2023 3:34 pm Other than referring you to Antares, I don't know. It does work for my in DP 11 over Ventura. They used to use iLok but I think they switched back in 2017 otr so.
Every owner of an Apple Silicon Mac needs to know this one.elarue wrote: ↑Tue Jun 06, 2023 5:35 pmOkay, dumb question. What do you mean by "launch DP in Rosetta?"James Steele wrote: ↑Tue Jun 06, 2023 3:38 pmShot in the dark, but try launching DP in Rosetta and then rescan the plugin. Sometimes that works.
Run Get Info on DP. You’ll see a box that, when checked, opens the app over Rosetta 2.
Ah, that's why I don't know anything about this. My MBP is from 2019 and still has an Intel chip. I did look for the box you mentioned and didn't see it there, but if it requires Apple Silicon, that might be why.mikehalloran wrote: ↑Thu Jun 08, 2023 8:15 amEvery owner of an Apple Silicon Mac needs to know this one.elarue wrote: ↑Tue Jun 06, 2023 5:35 pmOkay, dumb question. What do you mean by "launch DP in Rosetta?"James Steele wrote: ↑Tue Jun 06, 2023 3:38 pm
Oops. My mistake. Sorry.
Set up a signature with rig details. Helps when troubleshooting is needed.
HC Markus
Thanks for the tip! Now let's see if my fancy new signature shows up!
