Reconnect missing sound files from within a session?
ghobish
Post by ghobish »
I have an old session in which the original files were recorded in SD2; there were several take folders (1 for each of 5 songs), and the files within those folders all have identical names (e.g., "11-KIK44.sd2"). When I start the session, I have 2 tracks whose soundbites can't find their original files. However, the "Missing Sound Files" dialog box only shows 1 missing file for each track; it's probably confused by the 5 files missing for each track have identical names.
Is there a way to reconnect media from within the open session, i.e., select the missing soundbite and then (either through a right-click or some menu item, direct it to the original file the soundbite came from (I know what and where they are)? If there is such a command within DP I haven't been able to find it. (All of the other soundbites in the session do remember where they came from, in the same folders as these missing bites...)
Thanks-
Gary Hobish
A. Hammer Mastering & Digital Media
San Francisco, Ca
http://ahammer.com/mastering
Mastering: Mac Studio M1 MAX 2TB SSD, 64GB RAM, 32-core GPU, OS 12.6; DP 11.22, Waves, Izotope RX10 Advanced, Alloy, Nectar, PSP stuff, Plug-In Alliance, Metric Halo ULN-8 MkIV, Euphonix MC Control & MC Mix, Presonus Central Station, and (still) no air conditioning (but at least now there is airflow)
Annex: Mac Pro 2010 5,1 3.33GHz 12-core, 80GB RAM, 10.14.6, DP 11.22, Metric Halo ULN8 MkIV, MOTU 2408III
Re: Reconnect missing sound files from within a session?
Are the original audio files located in the Audio Files folder inside your Project folder or somewhere else? If somewhere else, see if dragging them into the Audio Files folder doesn't fix the problem. You can have DP convert them automatically into .wav at whatever resolution you want — either before or after.
If that doesn't do it, you can just drag them back into the project. If that still doesn't work, there are a few ways to fix that.
Once you've got everything back in place, deleting the aliases of the missing files is very easy.
DP 11.33; 828mkII FW, micro lite, M4, MTP/AV USB Firmware 2.0.1
2023 Mac Studio M2 8TB, 192GB RAM, OS Sonoma 14.7.2/Sequoia 15.2, USB4 8TB externals, Neumann MT48, M-Audio AIR 192|14, Mackie ProFxv3, Zoom F3 & UAC 232 32bit float recorder & interface; 2012 MBPs (x2) Catalina, Mojave
ghobish
Post by ghobish »
mikehalloran wrote: Mon May 15, 2023 8:51 pm Are the original audio files located in the Audio Files folder inside your Project folder or somewhere else? If somewhere else, see if dragging them into the Audio Files folder doesn't fix the problem. You can have DP convert them automatically into .wav at whatever resolution you want — either before or after.
Thanks Mike, let me clarify. It gets a little hairy. Everything is actually in the same hierarchy as when the session was created. The other tracks are finding the files right where they should be, in those same folders.
The files are not in the audio files folder- there are 5 "Take" folders (originally recorded in the Metric Halo MIO Console on location in 2011), and the contents of each folder is 14 files with the same name as in every other Take folder, so I cannot just move them to the Audio Files folder. (The attached image "Finder"will give you the idea, I've highlighted the tracks that DP won't find). ALL but 2 tracks are connecting properly via the path. If I could go back in time 12 years, I would have renamed the original files at the time!!)
Can't just drag them in, this session is edited. (Attached image "tracks")
Because the "Missing Sound Files" dialog box is confused (attached image "Missing Sound Files"), if I navigate to and select any of the like named files, ALL of the soundbites in that track fill in from that one file.
missing sound files.png (104.77 KiB) Viewed 1808 times
I know exactly each soundbite's original file location, which is why I was hoping to redirect the pointers to those files directly from each soundbite, or maybe from the Soundbite Info window, but this is apparently not a feature in DP.
(Feature request: when you right click a soundbite and go to "Reveal in Finder", if it can't be found it should give you the option of locating the missing file).
Thanks for thinking about my headache!
Gary Hobish
San Francisco, Ca
ghobish
Post by ghobish »
(I have submitted a "Reconnect soundbite to file" feature request to MOTU Support).
Gary Hobish
San Francisco, Ca
Sorry if I missed it, but isn’t there a “replace” function for soundbites? You tell it to start referencing a different audio file. If so could you make copies of the files you want to use, using different names, and then get DP to reference those instead?
ghobish
Post by ghobish »
bayswater wrote: Tue May 16, 2023 3:24 pm Sorry if I missed it, but isn’t there a “replace” function for soundbites? You tell it to start referencing a different audio file. If so could you make copies of the files you want to use, using different names, and then get DP to reference those instead?
Close, but neither "Replace Soundbite" nor "Reload Soundbite" seem to take the internal DP edge editing into account- they load the edited soundbite from the top of the audio file. Nice suggestion, though.
I HAVE to believe this function is here, but so esoterically named as to make it impossible to find!This should be what happens when you execute a "Reveal In Finder" command and DP can't find the file. It just gives up, when it could say "Hey, I can't locate the file, tell me where it is..."
Gary Hobish
San Francisco, Ca
ghobish wrote: Tue May 16, 2023 3:44 pm Close, but neither "Replace Soundbite" nor "Reload Soundbite" seem to take the internal DP edge editing into account- they load the edited soundbite from the top of the audio file.
Hadn’t thought of that. Would be difficult for DP to know how to apply old edge edits to new audio files.
waynepeet
Post by waynepeet »
In the Soundbites window, File column you can double click the file name and then navigate to reassign a soundbite.
DP used to be able to automatically connect soundbites to different audio folders within a project folder, which was pretty handy, you could put all the keepers in a folder, etc. Now it only looks in the "audio folder", but you can reassign as described above, so you can use multiple audio folders. I've complained about this to MOTU but no result.
Additionally if you re-assign a file with a different name (for instance like adding a "NR" suffix when saving a copy, after doing external noise reduction processing in RX) DP will crash on closing the file, every time. I've also mentioned this to MOTU but it hasn't been fixed for many versions.
Wayne Peet / Killzone Music / Los Angeles
MacPro 5,1 2010 upgraded motherboard 12 core 3.46 GHz, 64 GB RAM, NVIDIA GeForce GTX 760, MOTU 424 PCIe, UAD PCI, SSD drives, OS 10.12.x & 10.14.x
ghobish
Post by ghobish »
waynepeet wrote: Thu May 25, 2023 5:44 pm In the Soundbites window, File column you can double click the file name and then navigate to reassign a soundbite.
Wayne!! Dude! How are ya?
This WORKS- so tell me WHY the tech at MOTU didn't know this???
(saw my cousin Amy a few days ago!)
Gary
Gary Hobish
San Francisco, Ca
