Hi,
whenever I export a song that uses a patch list as MIDI file the program changes don't show up in the file. How can I achieve this?
Thanks everybody for your help
Please help: Transfer PRG Changes from Patch list into MIDI file
Re: Please help: Transfer PRG Changes from Patch list into MIDI file
How are you making the export selection? Try using the I-Beam to make your selection (timeline I-Beam vs Arrow object selection). If bringing back into DP and it shows up as clips - unpack the clips.
Hi CharlzS,
thanks, will try this later, I'm on the road
Solved: Transfer PRG Changes from Patch list into MIDI file
And it works. Thanks a lot, CharlzS.
