Hi all,
I'm 'reviving' an older post I made, with a little new information. The problem persists.
This is a problem that has developed, currently with a MIDI track only, where the project had been working fine up until now, and then appeared 'all at once.' All are MIDI tracks, with MIDI assignments to Eastwest Platinum orchestra, a typical setup for me. When I select a group of MIDI notes (always in Quickscribe window, almost always in Tracks & Sequences) DP immediately crashes. I have not done anything out of the ordinary as far as setup or unusual plugins, etc.
In my original posting it was suggested (thanks, Mike Halloran!) I add more RAM, due to the possibility of a memory leak, which I did (16 GB to 64!), but nothing changed. Workarounds are tediously slow, and any additional help would be greatly appreciated.
Using DP 11.21, 2020 iMac running Ventura, intel chip.
DP crashing when click/drag selecting
