Hello guys!
- FMiguelez
Hello guys!
Hi, amigos!
As some of you know, I had to move out from where I was and I had to build a new studio from scratch. The thing is that everything that could've go wrong did go wrong, and then some...
After more than a full year, the nightmare is almost over. The new place is 90% finished, but the rest, the accoustic treatment --which is probably the most important part-- has yet to be done.
I was feeling tired of being stagnated and frustrated by this whole situation, so I plugged the essential gear up. With the bare walls like this the room sounds like crap, but at least I can compose and do pre-production work while I do the treatment.
I hope I can do that soon, otherwise I can't mix anything like this! I didn't bother to connect the monitors yet... there's no point, so I'm using my desktop speakers to compose meanwhile (I can hear ugly resonances at D2 and its prominent first 3-4 harmonics).
So now that I'm finally back to being a musician, I'll be hanging out here with you guys again. I missed you and all the tech talk!
I was surprised I still remembered how to open DP. Surprisingly, the shortcuts, which I thought were all forgotten, came back to me as if I never stopped using them the moment I laid my hands on the keyboard with DP in my screen
See you around!
See you around!
Re: Hello guys!
Welcome Back FM!
Congrats on the new space... have fun treating the interior! Interesting, isn't it, that the better isolation a room provides, the harder one has to work at treating it to sound good inside. My son used to live in an old house with very thin walls, almost cardboard, and the rooms sounded great for drums as there was no containment of low frequencies.
I've developed some techniques for panel construction over the years. My fave is to glue a quick frame out of drywall edge metal ("corner bead") in place around the panel (3 or 6 Lb/Cu Ft rigid glass of preferred thickness, 3M 77 Spray Adhesive to hl din placed temporarily) then wrap with Guilford FR701 also glued (on back only) with Spray Adhesive. For larger clouds, a great support frame is Suspended Ceiling Main Beams attached behind rigid glass with self-tapping screws and fender washers.
You always need to think about mounting before fabric is wrapped!
Corner bead gives a clean edge and is super easy to cut to size using tin snips. I use 6 lb 1" material as facing for deeper traps containing low-density glass.
If you have unlimited money, you can buy everything. If you want to use only standard size panels, they are readily available, but still costly. But if you want/need to save money or have custom work, it is well worth self-building acoustic panels. The FR701 fabric has perfectly limited stretch and makes constructing nice looking panels fairly easy.
Attaching a couple of photos to give you an idea of before/after. Third pic shows a bass trap in process of construction.
- IMG_3155.JPG (2.04 MiB) Viewed 1027 times
- 63918126652__56606A5C-F7DA-4BE7-8B55-F4F9F9FF0E81.JPG (1.78 MiB) Viewed 1027 times
Re: Hello guys!
This pic shows my workbench/storage area, hidden behind sliding doors that are actually rigid 6Lb glass built using the same technique and hanging from Home Depot tracks. Great bass trapping and storage, all in one!
- IMG_3127.JPG (2 MiB) Viewed 1026 times
Re: Hello guys!
I hope Cedric is doing well. Give him treats for me!
Re: Hello guys!
We missed you Fernando. Glad you are back!
- FMiguelez
Re: Hello guys!
Markus, thank you so much for those pics and info! It looks great. That will come very handy when the time comes.HCMarkus wrote: ↑Sun Oct 02, 2022 8:41 am Welcome Back FM!
I will talk to you before I start doing the treatment, if that's ok with you. Perhaps you can give me a few things to mind, gotchas, or things you "wish you knew" before getting started
I've been doing some reading about this, and here's my plan in broad strokes, according to what I've understood so far:
---- I'll be doing freq response sweep tests with the software that gives you graphics and info as a guide
---- The panels will be of mineral wool, 4.5 inches thick and very dense.
---- Except for the ceiling cloud, all the panels will be movable. I don't know exactly where they'll go, but I have a good general idea. Given that it is recommended to leave a space between the wall and the panel the size of whatever thickness the panel is, being able to move them will let me test this bit, as well as experimenting with different positions.
---- Since mineral wool may be toxic if not handled properly, I'm planning on wrapping the panels with 2 layers of very thin plastic (the kind movers use to quickly wrap stuff up). That will prevent fibers from flying around. To prevent very high frequencies from bouncing off the plastic, I'll also wrap them over with "under-carpet" (it's a gray fabric that goes underneath carpets and wooden floors. It's like 3 mm thick and fluffy, so 2 layers around the plastic will hopefully make up for it). Then this will go covered with some kind of nice fabric, to make it look nice. Supposedly, with that gap in between the wall and panels, they become as effective as if they were twice the thickness!
---- At least half the room will have these panels, floor to ceiling, especially around the NRZ, all corners and the wall behind.
---- Once I get the waves interference, echoes and resonances under control, then I'll look into resonators, if needed.
What do you think?
That's it! What a rabbit hole this is! It's such a deep topic I wish I had the means to simply hire an expert and have him take care of it all! I'll do what I can following basic principles.
- FMiguelez
Re: Hello guys!
He is doing great! He's such a happy dog . Thanks for asking. He will love you for request... Mmmmhhh, yummy, treats for me!
Thank you, my friend! I missed it here!
Lookin' forward to the new DP which now goes to ELEVEN, like your song!
Re: Hello guys!
So good to read you again! Best of luck with the studio, FM.
Re: Hello guys!
Happy to chat anytime Fernando! It certainly sounds like you have a pretty solid plan for treatment. I'll PM you with my contact info.FMiguelez wrote: ↑Sun Oct 02, 2022 4:16 pm
What do you think?
One Concern: Depending on the frequencies involved, I'm not sure if wrapping the panels with a non-permeable plastic and other layers is a good idea from an acoustic perspective. As you probably know, acoustic panels absorb sound by converting acoustic energy to heat as moving air excites the panel fibers. You may want to do some research in that area. I believe neither rock wool nor fiberglass has been determined to be a health risk, especially if the fibers aren't floating around. Whatever you decide to do, I'd recommend building the panels outside of your space, because during construction there definitely ARE fibers, and they can, at the least, cause skin irritation. I built mine outside under a shade structure on a couple of those big, white plastic Costco tables. A helper is definitely nice to have when stretching cloth around larger panels.
My experience (using rigid fiberglass like Dow Corning 703/705) has been that once the panels are fabric wrapped and in place, there is no fiber shed. But I also understand and respect your health concerns.
Having panels that can be placed where needed is a great approach, and mounting off the walls definitely enhances low frequency effectiveness. Looks sharp, too.
I used the ceiling/wall junctions, and an area above a low-ceiling closet for bass trapping instead of vertical corners; saves floor space that way.
Building a studio is a lot of work. It is also enjoyable, especially when you end up with a great-sounding room!
- FMiguelez
Re: Hello guys!
I'm concerned about it too, that certain high frequencies might bounce off of the plastic and not get absorbed properly, probably creating some kind of imbalance.HCMarkus wrote: ↑Sun Oct 02, 2022 7:40 pm Happy to chat anytime Fernando! It certainly sounds like you have a pretty solid plan for treatment. I'll PM you with my contact info.
I'm glad you mention that.
I'll definitely research that issue more. Over at GS I've read mixed opinions. As far as I could tell, a couple of guys who did wrap the panels in plastic reported no issues and seemed happy, but they did warp the plastic in a couple of layers of fluffy cloth-like fabric to compensate.
I follow a couple of acoustics specialists in YT, so I'll probably reach out to them and ask them directly about that particular issue.
I'll report what I learn here.
This was my experience in my previous studio too. I never saw or felt any fibers around and I never got sick. To tell you the truth I don't know why I suddenly became paranoid about those fibers. I'll have to do more research here as well.HCMarkus wrote: I believe neither rock wool nor fiberglass has been determined to be a health risk, especially if the fibers aren't floating around. Whatever you decide to do, I'd recommend building the panels outside of your space, because during construction there definitely ARE fibers, and they can, at the least, cause skin irritation. I built mine outside under a shade structure on a couple of those big, white plastic Costco tables. A helper is definitely nice to have when stretching cloth around larger panels.
Exactly! It's the kind of thing that requires a lot of work and effort, but it is all handsomely rewarded with a room you can enjoy listening to music in, and the confidence it will translate very well.
- FMiguelez
Re: Hello guys!
Thanks, Stubbs! It feels good to be back from self-imposed music exilestubbsonic wrote: ↑Sun Oct 02, 2022 7:06 pm So good to read you again! Best of luck with the studio, FM.
Re: Hello guys!
Great to see you hanging out here again, Fernando! Congrats on getting the new studio together.
- FMiguelez
Re: Hello guys!
Hi, Tritone! Thanks my friend.Tritonemusic wrote: ↑Mon Oct 03, 2022 9:50 am Great to see you hanging out here again, Fernando! Congrats on getting the new studio together.
You just reminded me of a little article I read a couple days ago about the "tritone"...
Turns out, to my dismay, there was not really a "diabolus in musica" concept in the Middle Ages the way I pictured . It's not mentioned like that in the old sources; apparently, it was a fantasy created centuries later... You can even hear it bare and prominently in some Ars Antiqua pieces!
Cheers to you and to the interval that captivated the imagination of so many for so long!
Re: Hello guys!
Hey, we've missed you. Welcome back!
Re: Hello guys!
Brother 'Nandito!
Good to see you again my man.
