Well dang it, the latest Resolve version - the app I use most to generate my income - requires Big Sur minimum. I'm on Catalina.
What issues have you encountered upgrading from Catalina to either Big Sur or Monterey with DP and your plug-ins and virtual instruments (if any)?
I have hundreds of plug-ins for audio and video; a few dozen I use primarily in DP.
My tracking room MacPro is stuck on Mojave. I fear that if I have to update plug-ins to be compatible with OS 11 or 12 in my mixing room, they might not show up when i go back and forth from tracking to mixing.
What could I expect if I upgrade my OS?
Catalina > Big Sur > Monterey
recording: Mac Mini 2018 - 32GB RAM - 3.2 GHz 6-Core Intel Core i7 - two Focusrite Scarlett 18i20 - OS 12.7.4 - DP 11.23
mixing: MacPro7,1 - 256GB RAM - 2.7 GHz 24-Core Intel Xeon W - Focusrite Scarlett Solo - OS 12.7.4 - DP 11.23
Both computers: Kontakt Komplete 13 VIs and effects. Effects: FabFilter, Sonnox Oxford, SSL, PSP, UA, iZotope. VIs: Cherry Audio, AIR Tech, GForce, AAS, East-West, Garritan, Best Service, Kilohearts, Brainworx, UA
Re: Catalina > Big Sur > Monterey
None except with Apple Silicon.
That is a very real possibility. If it becomes a problem, something will need an upgrade.My tracking room MacPro is stuck on Mojave. I fear that if I have to update plug-ins to be compatible with OS 11 or 12 in my mixing room, they might not show up when i go back and forth from tracking to mixing.
- joelfriedman
Hi, not sure if this is pertinent to you, but when I went up to 12.5 on my iMacPro I had to update Waves to v.14 and it now totally conflicts with Avid Sibelius. Crashes SIbelius. I have to take the Wave Shell out to disable Waves. Meanwhile Waves works fine with DP.
Joel Friedman
iMacPro 2017 3.2 GHz, OS 13.6,3 32GB RAM, 4 1 TB HD's (boot, project, and samples), MOTU UltraLite MK4, Nektar Impact LX88
DP 11.3, MachFive 3.2, MX4 2.2, Ethno 2.01, Komplete 14 Ultimate (don't ask...), Sibelius Ultimate, Symphobia v. 1.06, assorted libraries...
MacBook Pro M1 16 GB RAM OS 13.6.3
My big fear. I can't upgrade my 2012 MacPro any more than it is already. I can't run Massive X from Kontakt on it, but so far, that's the only VI or effect I can't trade between my two Macs.mikehalloran wrote: ↑Mon Aug 01, 2022 2:48 pmIf it becomes a problem, something will need an upgrade.
I also use that tower as my archiving station for my LTO system, and I'm kind of stuck there, too, unless I buy a newer Mac and PCIe expansion kit.
I may have to stick on the last beta of Resolve for the foreseeable future. It's pretty stable, so that may be OK.
Thanks for the replies!
Huh?Jim wrote: ↑Tue Aug 02, 2022 10:50 amMy big fear. I can't upgrade my 2012 MacPro any more than it is already. I can't run Massive X from Kontakt on it, but so far, that's the only VI or effect I can't trade between my two Macs.mikehalloran wrote: ↑Mon Aug 01, 2022 2:48 pmIf it becomes a problem, something will need an upgrade.
A 2012 MP 5.1 is supposed to have a Metal compatible GPU. If so, it can be upgraded to Catalina. Big Sur can be done with an easily done hack — and quickly undone via APFS Snapshots if you don’t like it. Many threads on this.
Sounds like I've been misinformed. I was under the impression that High Sierra is the latest Apple approved OS, but that Mojave was available with a hack.mikehalloran wrote: ↑Tue Aug 02, 2022 11:22 am A 2012 MP 5.1 is supposed to have a Metal compatible GPU. If so, it can be upgraded to Catalina. Big Sur can be done with an easily done hack — and quickly undone via APFS Snapshots if you don’t like it. Many threads on this.
Looks like I've got some googlin' to do. Thanks, Mike.
