I Need To Rescan the AU VIs and Plug-ins
- buzzsmith
Hi, all!
Long time, no see...
Anyway something happened today and DP is not seeing ANY of my AU VIs or plugins.
They are not even showing in the Preferences>Audio Plug-ins list. Only MAS and some never enabled VSTs.
So there appears to be no way to re-examine when there are no AUs in the list to re-examine?
Is there some other way to re scan? Like maybe trash a preference or something along that line?
I did, of course, try relaunching DP and two reboots.
Thanks very much!
Buzzy
Thanks very much!
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
Focal Twin6 Be(s)
Re: I Need To Rescan the AU VIs and Plug-ins
Hi Buzzy,
Open Preferences/Audio Plugins and you should see the button to reexamine.
What isn't made clear is that you have to hilite them before the button works. If none are showing, more instructions are found on pg 916 of the User Guide (DP 11) or search the one you have for reexamine plug-ins to find the correct page.If you wish to reexamine a plug-in or plug-ins, select the desired plug-ins and press the Reexamine button.
- Screen Shot 2022-06-17 at 7.35.58 PM.png (312.5 KiB) Viewed 1199 times
Except they say
buzzsmith, can you confirm your AUs are in the system level Components folder? So, Mac HD > Library > Audio > Plugins > Components as mine are...and where they belong I think.
Sounds more like the AU’s got moved inadvertently to somewhere they oughtn’t be or something.They are not even showing in the Preferences>Audio Plug-ins list.
Is the system shown your signature up-to-date?
I think sometimes whether DP is in 32-bit or 64-bit mode can affect whether plugins appear or not.
Did you find the plugin components on your Mac as Dix suggested?
You might try saving your preferences file, then reinstalling DP if all the components are still where they should be. After reinstallation of DP, test to see if your plugins show up. If all appears well, try replacing the newly-created DP Preferences with your saved Preferences. If all is still good, you should be back where you started.
Good luck!
Good luck!
- buzzsmith
Sorry! I just saw this.dix wrote: ↑Fri Jun 17, 2022 10:30 pm Except they saySounds more like the AU’s got moved inadvertently to somewhere they oughtn’t be or something.They are not even showing in the Preferences>Audio Plug-ins list.
(I thought I had notifications turned on when a reply was posted.)
Yes, Dix. there are 545 items in the Components folder.
Thanks.
Buzzy
Focal Twin6 Be(s)
Focal Twin6 Be(s)
- buzzsmith
I think so, stubbsonic.stubbsonic wrote: ↑Sat Jun 18, 2022 12:01 pm Is the system shown your signature up-to-date?
I'm the current active user.
Under the I have the option of "Log Out Buzzy Smith..."
Thanks.
Buzzy
Focal Twin6 Be(s)
Focal Twin6 Be(s)
- buzzsmith
Mike, I found that page in my 9.52 manual but it is only showing the reexamine option for items that are actually currently showing up within DP in the Preferences>General>Audio Plug-ins list. Only MAS and (unused) VSTs are available.mikehalloran wrote: ↑Fri Jun 17, 2022 7:27 pm Hi Buzzy,
Thanks,
Buzzy
Focal Twin6 Be(s)
Focal Twin6 Be(s)
To determine whether DP is running in 32 or 64 bit mode, Get Info on the DP app in the Finder and see if the 64-bit box is checked.buzzsmith wrote: ↑Sun Jun 19, 2022 8:40 amI think so, stubbsonic.stubbsonic wrote: ↑Sat Jun 18, 2022 12:01 pm Is the system shown your signature up-to-date?
Thanks.
Buzzy
Just a shot in the dark here, but make sure that the plug-in called "MAS Audio Unit Support" didn't get unchecked somehow in the Plug-Ins preferences. If it's unchecked, none of your AU plug-ins will load.
- buzzsmith
Thanks, James.James Steele wrote: ↑Sun Jun 19, 2022 12:46 pm Just a shot in the dark here, but make sure that the plug-in called "MAS Audio Unit Support" didn't get unchecked somehow in the Plug-Ins preferences. If it's unchecked, none of your AU plug-ins will load.
I did check that earlier today and even tried disabling and re-enabling to no avail.
Appreciate it!
Buzzy
Focal Twin6 Be(s)
Focal Twin6 Be(s)
- buzzsmith
I checked and it's indeed running in 64 bit.dix wrote: ↑Sun Jun 19, 2022 11:38 amTo determine whether DP is running in 32 or 64 bit mode, Get Info on the DP app in the Finder and see if the 64-bit box is checked.buzzsmith wrote: ↑Sun Jun 19, 2022 8:40 amI think so, stubbsonic.stubbsonic wrote: ↑Sat Jun 18, 2022 12:01 pm Is the system shown your signature up-to-date?
Thanks.
Buzzy
Focal Twin6 Be(s)
Focal Twin6 Be(s)
I do remember there is a prefs file you can delete which forces a rescan of ALL plug ins. Don’t remember exactly which file that is, however. Not in front of studio computer so can’t check at the moment.
- buzzsmith
I basically posted this same question in the MOTU Digital Performer group on FB.
One guy is pretty convinced that an Apple automatic update is what crashed the Audio Units on 10.11.6.
This is what I'm showing within the past four days.
(I did disable the auto-update feature earlier today.)
Buzzy
Buzzy
- Apple Updates.jpg (101.89 KiB) Viewed 1052 times
Focal Twin6 Be(s)
Focal Twin6 Be(s)
Of course he does.
There is an old issue with plug-ins that affected a MacOS and it involved having an iPhone. Apple resolved it quickly but it affected a few people around here. Since I was one of those who wasn’t affected, I don’t remember any of the details nor even how to search for those old threads but somebody should.. I don’t think it was El Cap but maybe it was.
