- Dell Latitude 5520 (Realtek 16-bit soundcard) running Audacity audio software
- Tascam Da-30 MkII
- MOTU 4Pre with power supply
- High quality coax cable
- 1m USB cable
- Tascam DA-30 MkII S/PDIF coax output to MOTU 4Pre S/PDIF coax input
- MOTU 4Pre USB output to Dell Latitude 5520 USB input
- If I set the MOTU console bit rate to 48KHz and clock source to S/PDIF (the ideal), Audacity sees the MME MOTU S/PDIF, but shows a hardware error when trying to record:
I have disabled any system interruptions or power-downs of USB, but have not checked the permissions. However, Audacity sees the MOTU 4Pre S/PDIF and will record under certain circumstances. So, it seems unlikely to be a permissions issue.-9999 Unanticipated host error: this means means "something is wrong". And appears to most often be due to either:
A lost connection to a USB audio device.
Recent Windows / Mac update requiring that user gives permission for Audacity to access the microphone.
- If I set the MOTU console bit rate to 48KHz and the clock source to internal, then the MOTU 4Pre shows 48KHz constantly lit, but 44.1KHz flashing, and Audacity records, but with dropouts and syncing issues.
- If I set the MOTU console bit rate to 44.1KHz and the clock source to S/PDIF, Audacity records but with with that grainy bitty sound, like a low quality sample.
- I haven't tried setting the MOTU console bit rate to 44.1KHz and the clock source to internal.
