Lane scroll position resetting
Is it just me, or does the pitch lane reset its scrolled position to the top every time you change anything about the track layout? This is extremely irritating. Attached are a before adding a volume lane, and after adding one. Pitch scrolls itself to the top. Argh.
- Screen Shot 2022-05-29 at 3.02.47 PM.png (140.67 KiB) Viewed 688 times
- Screen Shot 2022-05-29 at 3.03.13 PM.png (137.42 KiB) Viewed 688 times
Re: Lane scroll position resetting
Well, that is annoying. Definitely submit a tech-link.
Not seeing this here. The pitch lane stays put after adding lanes, reordering tracks, or changing track layouts from the View menu for me. ...Stubsonic's post implies they might be having the issue, but then suggests you submit a tech-link, so I'm not sure.
Not seeing it, either. Could there be a Preference setting?
I can't reproduce this either.
Couldn't reproduce. Tried the example steps. My post was commiseration only.
YES! Happens here too! I couldn't reproduce it at first, then after a few tries it started happening. I'm combing through the preferences for clues... what is your setup?
828x MacOS 13.6.7 M1 Studio Max 1TB 64G DP11.31
So I got rid of my prefs, opened her back up... same problem.
MacBook Pro 15,3
MacOS 12.4
DP 11.1
MacBook Pro 15,3
MacOS 12.4
DP 11.1
