When working in 29.97df, DP 9 & 11 won't let me zoom in all the way while in the sequence window
goosetunes
Post by goosetunes »
I recently upgraded to masOS Mojave from High Sierra. Running High Sierra, DP 8.07 used to work fine and had no issue handling audio post projects that were in 29.97df. DP 9.52 and a trial of DP 11.1 lock up whenever I open the sequence window and try to zoom in on a waveform... but this only happens with 29.97df projects. All other framerates and measures work fine.
Since upgrading to Mojave, DP8.07 won't open, it just crashes immediately. And DP 9.52 and 11.1 still lock up whenever I'm in a 29.97df project and try to zoom in on a waveform in the sequence window.
I need to be able to work in 29.97df for various TV projects. I have 3 different versions of DP that can't do it. Is there a fix for this that I'm missing?
DP 9.52, MachFive 3, MX4, Kontakt5, Omnisphere, PLAY, 828mk3 Hybrid FW-USB2, 8-Pre, MIDI Express XT, Mid-2012 MacPro 2 x 3.46 GHz 6-Core Intel Xeon, 64 GB RAM, Graphics Radeon RX 580 8192 MB, OSX 10.14.6.
