So I have a 2013 trash can Mac running Mojave and DP9.
This week I’m upgrading to DP 11.04.
Any reason why I shouldn’t upgrade to Monterey at the same time?
Tia brolly
Upgrading
Re: Upgrading
Mojave was the last MacOS to run 32bit apps and plugins. Other than that, no reason I can think of. A few things:
Have a recent Time Machine backup before you start. If you discovered that the Monterey update was premature, you have a 24 hour window to roll it back without doing a full Time Machine Restore.
viewtopic.php?t=64689
If you have Autotune or any other plugin that uses the CodeMeter Runtime for licensing, update it before installing Monterey. You will have CodeMeter.app in Applications and a panel in System Preferences if you do.
viewtopic.php?f=4&t=69862
If your MacPro 6.1 still has its AHCI SSD inside, you can triple the Read/Write speed and increase the capacity to 2TB for around $200 last I priced it out — takes 5 minutes to install plus data transfer.
