hey, does anybody have any examples of how you are using the expert mode? i am a bit foggy on how i can use it to cross-fade strings, or whatever - i assume you use it in conjunction with MIDI learn. any tips would be appreciated!
thanks -
joel
msi expert mode tips?
In the specific example of crossfading, you don't need to use Expert mode.. simply load the two string patches to be crossfaded into two slots, both set to the same MIDI channel, and use Modulation-mode MIDI learn (Alt-right click) on the volume knob of each of the two parts, with one of the two parts set to negative (red circle to the left). On the other hand you'd use Expert mode to key-switch between Arco and Pizzi or Tremolandi, for example.
Mac MDD dual 1GB/1.25GB RAM/160GB internal disc/MOTU PCI-424/2408 MK3/MTP AV
MAC OS X 10.3.8/ Digital Performer 4.52/Cubase SX 3.02
MAC OS 9.2.2/Digital Performer 3.11/ Cubase VST_32/5.2pb
