Looking for a 3 switch foot controller programmable on a Mac
I’m looking for a 3 switch foot controller that I can use to program the Command, Option and Shift keys on a Mac. All the ones I see require a PC to program it first. Mine is on loan and I don’t want to borrow it back just to program a footswitch.
- FMiguelez
Re: Looking for a 3 switch foot controller programmable on a Mac
I use this one for any type of clicking to protect my hands, and it's amazing. Supposedly it can be also be programmed to perform any key-combinations (but I haven't tried doing that)>
https://kinesis-ergo.com/shop/savant-el ... ple-pedal/
Some time ago a wrote a post about using this pedal and the sticky keys combo to avoid hand injuries during prolonged computer sessions and safe DP keyboard shortcuts here>
https://www.motunation.com/forum/viewto ... 41#p568241
Looks like the right tool—order has been placed. There are many, inexpensive copies but they require programming on a PC.
It’s quite tedious to place left hand fingers onto the keyboard with my right hand every time I need a modifier—in DP, that’s a lot as I edit choir tracks.
Thanks for your help!
Not cheap, though. Looks sturdy, and the config process is ideal. Is there no way to take some MIDI thingy and convert those to key commands?
Interesting. Would you use the pedals to click and press modifier keys on the keyboard, or the other way around?
My left arm is paralyzed going on 12 years. Therapists tell me that, if I keep trying, I can use it on its own. Sorry but I’m trying to get work done. My current method is to place my finger on the keyboard with my right hand. Command, Option or Shift while I use my trackpad. Programmable mice never did it for me and I know there are ways to program the Magic Trackpad 2 but a foot controller for those three keys should help me work the way I like.
I’m looking at Stream Deck for a couple of years and watching as the app improves. It looks like it’s finally ready for prime time so I will pull the trigger. Not certain which version yet.
https://www.elgato.com/en/gaming/stream-deck
Now that the day gig no longer exists and I’m spending so much more time in DP, Finale etc., I need to begin optimizing my workflow
Go for the StreamDeck XL. Much better than the standard one.
**Leigh
**Leigh
I don't care what you play. I care how you play.— Karl Berger
iMac Pro 3 GHz 10-Core Intel Xeon W, 128GB RAM, Mac OS X 14.2, DP 11.3
I ordered one up and figured out how to program it easily enough but, unfortunately, this will not do what I need. Per Kinesis Support:FMiguelez wrote: ↑Mon Feb 15, 2021 8:22 am I use this one for any type of clicking to protect my hands, and it's amazing. Supposedly it can be also be programmed to perform any key-combinations (but I haven't tried doing that)>
… if you intend to use the SE2 to modify keypresses on a keyboard, this will not work, MacOS has a limitation where it will not allow one USB device to modify another.
I just got off the phone with Apple's Accessibility Support group. There's no way to get the Magic Trackpad 2 to do the three things I need: Shift-Click-Drag, Option-Shift-Drag and Command-Click-Drag. The only workaround is to pull up the Accessibility Keyboard, click on the area in the Dp track I want, click onto the modifier key in the Accessibility Keyboard, go back to my track to highlight what I need—but this does work. It's not as fast as lifting my left hand with my right and placing a left finger onto the keyboard like the dead weight that it is.
Time to explore programmable mice — haven't used one since the PPC days when the button to program was the right-click.
I still thank you for the suggestion. Now we know.
Everyone's backordered till late March, it appears but I've placed an order. I'll post how it works out for me.Go for the StreamDeck XL. Much better than the standard one.
I don't understand. I can press and hold Control on the USB keyboard and left-click on my USB mouse. How is that different?mikehalloran wrote: ↑Wed Feb 17, 2021 11:51 am … if you intend to use the SE2 to modify keypresses on a keyboard, this will not work, MacOS has a limitation where it will not allow one USB device to modify another.
This is a great mouse Mike: https://www.amazon.com/Logitech-Master- ... 238&sr=8-5
And the newer version 3 is probably as good or better, just $40 more!
A lot of programmability, and I love the side scroll wheel for horizontal scrolling in DP.
I don't understand it either but it is.stubbsonic wrote: ↑Wed Feb 17, 2021 12:34 pmI don't understand. I can press and hold Control on the USB keyboard and left-click on my USB mouse. How is that different?mikehalloran wrote: ↑Wed Feb 17, 2021 11:51 am … if you intend to use the SE2 to modify keypresses on a keyboard, this will not work, MacOS has a limitation where it will not allow one USB device to modify another.
Likewise, I cannot press the Option key on one keyboard to modify another. I have two keyboards up right now. Option g produces © on either 'board but the Option key pressed on one will not modify g on the other.
It looks like I will have to get Steermouse @ $19.95 and then find the right 5 or more button mouse so that I can program 3 of the keys to Shift, Option, Command or Shift-Click, Option-Click and Command-Click while leaving the two main buttons for the normal L and R-Click functions.
https://plentycom.jp/en/steermouse/
Fortunately, returning the foot controller on Amazon is easy. I've already re-set it to its Default.
I keep coming back to this or the 3. Since Steermouse supports them, looks like the way to go. Perhaps there's native support for what I need to do.HCMarkus wrote: ↑Wed Feb 17, 2021 12:47 pm This is a great mouse Mike: https://www.amazon.com/Logitech-Master- ... 238&sr=8-5
Update, I went for this version of the 3. Don't know what makes it Mac specific but the price is the same as the other 3.
https://smile.amazon.com/exec/obidos/AS ... =0&ie=UTF8
Because of my age and handicap, I may be able to get Medicare to cover some of this. We'll see…
That's why I asked. I figured it would be easier anyway to press the modifier keys on a normal keyboard, and use the foot switch as a mouse button. But I've never tried any of the above. It does look like possible way to improve productivity in some repetitive tasks in design apps.mikehalloran wrote: ↑Wed Feb 17, 2021 11:51 am… if you intend to use the SE2 to modify keypresses on a keyboard, this will not work, MacOS has a limitation where it will not allow one USB device to modify another.
That is the default setting.
Unfortunately, that can't work for me. I hit the modifiers on the keyboard with my right hand and activate the left click on the mouse with the switch, ok so far…
Now I've clicked but how do I drag? My only working hand is holding the modifier. Unfortunately, releasing the modifier key disables the (modifier)-Click as you try to Drag.
The only workaround is the Accessibility Keyboard in System Preferences as I mentioned before. I can use the switch to select a modifier but leaving the grid releases the key — still no Drag unless I do it all with the mouse. Sticky Keys work but it's still faster and easier placing my paralyzed finger onto the keys.
Absolutely. DP, too but not what I need done.It does look like possible way to improve productivity in some repetitive tasks in design apps.
I guess sticky keys is all there is for this scenario. I used it when I had one hand out of commission temporarily, and it worked, but never got used to it. Modifier keys on a footswitch, if it exists, seems awkward, but I can see that would work if you could do a mod and sometimes a click with your feet and just move the mouse around with a hand.
Did you look at the new version of voice control with Catalina?
I'm using a G502 mouse with Steermouse as the driver. Works well. Very configurable.
