Upgrading interfaces ... opinions wanted
I have a 2008 Mac Pro and I'm running (2) 2408's.
Eventually time will catch up with me and I'll upgrade my computer. I'm looking into interfaces that will get me at least into the world of recent tech.
I have my eye on:
Antelope Audio Orion 32+ - https://en.antelopeaudio.com/products/orion-32-gen-3/
MOTU 24Ai USB / AVB / iOS Interface
I would go with UAD but need more than 16 channels and when you start getting into 2 16x's, prices start to get UP there when compared to MOTU.
I also like the Antelope Orion because of the 32 channels.
Anyone have experience with these interfaces and/or suggestions?
In regards to outputs ... all ADAT outputs are fine as that's what I'm using currently.
I don't mix so I don't need all analog outs. I need a lot of inputs with the ability to get killer CUE mixes with onboard DSP/Effects. I'm using all outboard gear at the moment for adding verbs, compression, EQ to headphone mixes because the 2408's don't have FX available on them.
I LOVE the direct hardware play through because I NEVER have to worry about latency but with today's interfaces, the ability to add FX and keep latency little to none is what I need to start investing into.
I have my eye on:
Dual Quad-Core 2.8 GHz Mac Pro 3,1 • Yosemite • 24 GB RAM • MOTU 2408mk3 (x's 2) • DP 10.xx • Finale 25 • Logic • PT 12 • +outboard gear
Re: Upgrading interfaces ... opinions wanted
You might also look at interfaces from RME. Their TotalMix FX (config software) is very flexible.
Can you use ADAT ins and a second device as an ADC?
Wonder, I have the original Orion 32 (actually had 2) and ran it as a back up playback system on the road. The chassis was anything but road worthy because the rack ears would snap off. Sonic wise, it sounded ok but I felt it could've been better. I decided to sell one and keep one for my studio. I ended up getting the Black Lion mod for it and it opened up the stereo field a bit, and I got to hear more depth in my mixes. The problem that I've experienced over the last couple of years is Antelopes drivers. They don't have much support for legacy units so getting it to work with Catalina is a crap shoot. It works, but I doubt once Big Sur is fully supported by most companies, my Orion probably won't have the proper drivers. At this point I use my Orion 32 as an interface for my analog outboard gear for hardware inserts. The latest version of the 32 seems promising but if it were me, I'd go with the 24 i/o - 24 a/o, or the Apollo 16. I use both and love how they sound. I don't have the 24 i/o, but I have the 24 a/o. If you have the ability to do use ADAT, you don't need the 24/i/o, you can use 24 channels of ADAT i/o on the 24 a/o and still have 24 channels of analog outs! The Apollo with the built in DSP is dope and you pretty much can't go wrong with that unit! I use the Black face Apollo 16 which is cool but the new 16X has 50% more power and supposedly better converters.
Lastly, the latest Orion 32+ needs to run on at least a 2012 Mac so it won't work with your machine.
Check this out: https://support.antelopeaudio.com/suppo ... ad-section
Hope this helps.
Hope this helps.
Great family and friends!
F. Douglas
F. Douglas
I've been very happy with my 828ES...not enough inputs for you (unless you expand via litepipe) but the flexibility is excellent, as is the sound. The Thunderbolt connectivity is a plus for the future, although I am running via USB now and it is working great.
I do favor an outboard Lexicon reverb unit for tracking monitor reverb though; not crazy about the built-in MOTU 'verb.
HC Markus
I'd go with a couple of MOTU AVB interfaces. Like a 1248 and a 24Ai. Or maybe a 8pre-es and a 24Ai.
Martin
Martin
Martin Baird
martin@vmw.us
DP 10, MachFive, Electric Keys, 828es, MTP A/V USB
Mac Pro 2 x 3.33 GHz Six-Core, Mac OS X 10.14.6
martin@vmw.us
At the moment, I use my 2408's as suchstubbsonic wrote: ↑Wed Feb 03, 2021 11:22 am You might also look at interfaces from RME. Their TotalMix FX (config software) is very flexible.
BANK A = ADAT
BANK B = ADAT
BANK C = ANALOG
I do have an Alesis HD24 I "can" use as my ADC.
I'll look into RME. I forgot about them as a contender.
A HUGE deciding factor is the ability to add FX to headphone cues. If the interface doesn't have on-board DSP, I won't do it. That's 80% of the reason for the upgrade.
You're the third person I've heard from that have had major driver issues. I personally know 4 people with Antelope interfaces. 2 love them. 1 had major driver issues. 1 had two units that went bad and had to get replacements.kwiz wrote: ↑Wed Feb 03, 2021 2:46 pm Wonder, I have the original Orion 32 (actually had 2) and ran it as a back up playback system on the road. The chassis was anything but road worthy because the rack ears would snap off. Sonic wise, it sounded ok but I felt it could've been better. I decided to sell one and keep one for my studio. I ended up getting the Black Lion mod for it and it opened up the stereo field a bit, and I got to hear more depth in my mixes. The problem that I've experienced over the last couple of years is Antelopes drivers. They don't have much support for legacy units so getting it to work with Catalina is a crap shoot. It works, but I doubt once Big Sur is fully supported by most companies, my Orion probably won't have the proper drivers. At this point I use my Orion 32 as an interface for my analog outboard gear for hardware inserts. The latest version of the 32 seems promising but if it were me, I'd go with the 24 i/o - 24 a/o, or the Apollo 16. I use both and love how they sound. I don't have the 24 i/o, but I have the 24 a/o. If you have the ability to do use ADAT, you don't need the 24/i/o, you can use 24 channels of ADAT i/o on the 24 a/o and still have 24 channels of analog outs! The Apollo with the built in DSP is dope and you pretty much can't go wrong with that unit! I use the Black face Apollo 16 which is cool but the new 16X has 50% more power and supposedly better converters.
Hope this helps.
I was looking into the 24Ai.MartinBaird wrote: ↑Wed Feb 03, 2021 6:20 pm I'd go with a couple of MOTU AVB interfaces. Like a 1248 and a 24Ai. Or maybe a 8pre-es and a 24Ai.
Martin
I don't necessarily need pre's as I have enough outboard preamps.
I assume the 24Ai has on-board DSP for effects to feed the live inputs?
Might want to check the offerings from Lynx as well.
wonder wrote: ↑Thu Feb 04, 2021 8:56 amI was looking into the 24Ai.MartinBaird wrote: ↑Wed Feb 03, 2021 6:20 pm I'd go with a couple of MOTU AVB interfaces. Like a 1248 and a 24Ai. Or maybe a 8pre-es and a 24Ai.
Martin
I suggested the 1248 and 8pre-es just trying to get you to 32 inputs. Maybe I misunderstood. I think the MOTU AVB interfaces are underrated or under appreciated and the variety of offerings very cool.
MB
Martin Baird
martin@vmw.us
martin@vmw.us
It does.Like the whole AVB lineup. https://motu.com/products/avb/24ai-24ao/mixing.html
