Hello everyone,
I am new to DP and I am having a problem with digital artifacts when I play. https://sndup.net/2hmy here is a short audio (I recorded it on my phone so this was the best way I found to share it) of where the problem is. This is recording from VST but I get this no matter what. I have tested it in other DAWs and DP is the only one that is having this issue. Thanks for all the help.
Problem with digital artifacts
- Primary DAW OS: Windows
- FMiguelez
Re: Problem with digital artifacts
I'm so not clicking on that link...
The posts seems a bit suspicious. What version of DP are you using?
I understand your concern and if you show me a better way of uploading audio online in sort of imgur fashion I will upload it there. My version is 10.11.83650
Soundcloud is a good place to post.
Have you checked DP's buffer size?
I was gonna post there but ypu need to create an account and even after that it doesn’t support M4A or I have to download an app which is all too long of a process with no guarantee at the end. Best I can do from my phone is this: https://gofile.io/d/bi449b , the audio is right there and if you have a problem with clicking the link or with the page then google gofile.io; they also have patreon and you can google “gofile.io scam” or there are site checkers online like virustotal and kaspersky have something like this. I don’t want to spend ages looking for a way to upload this.
This sounds like buffer problem so I will check that. Thanks for proposing some kind of solution.
