Chopin - 'Winter Wind' Etude Op.25 No.11 in Am
Posted: Sat May 23, 2020 4:42 pm
by muzika
Back To The Basics #3
w/DP10 = Sounds much better than any other DAW, IMO.
https://youtu.be/mAkMQuSO8LM
Re: Chopin - 'Winter Wind' Etude Op.25 No.11 in Am
Posted: Sat May 23, 2020 4:50 pm
by FMiguelez
Did you play or program this, or both?
What piano VI are you using? How much or how little EQ are you using?
At first I thought it could be a bit too warm or muddy in the bottom, but it's more likely my room and speakers are at fault.
I like it. It does't sound harsh
I think that counts more for your sound than the DAW where it was made, unless it would sound
drastically different in other DAW with the same VI and settings, which I doubt.
Posted: Sat May 23, 2020 5:19 pm
by muzika
To FMiguelez:
We cannot express the performance of the piano in this way by programming as far as I know. Can you?
Custom made VI
Almost non EQ but just add limiter and a bit muddy in the bottom which you mentioned it, 'cause no editing.
Posted: Sat May 23, 2020 5:30 pm
by FMiguelez
muzika wrote:To FMiguelez:
Not without spending countless hours editing and mousing around... And the results are seldomly as good as only editing a great real performance.
I usually end-up doing both... Play my best performance and then edit --> My MIDI keyboard doesn't have the same pulsation as my real piano, so I always end up doing mistakes in the keyboard which I must then edit and correct in DP.
muzika wrote:
Custom made VI
Very cool.
What do you mean "back to basics"? Are you a professional pianist doing some sort of piano retraining? That piece is anything but basic to me!
Posted: Sun May 24, 2020 12:17 am
by muzika
I agree with you that 'Play my best performance and then edit' for the ensembles. But not for solo performance 'cause I don't wanna play with clicks.
See this about Back To The Basics
From YouTube:
As all the work has stopped it by COVID-19, I am during the piano special training since the student. But it's to say that the exercise of the piano is a part to compose music that I am different from other people.
