To me, by definition, the MIDI Editor includes the multi track selector functionality, which I don't see in the pics of sub window in P lite...or maybe it's just hidden, or implemented differently. If, say, you were to shift-click another MIDI track, maybe it's MIDI notes would be seen in the sub-window too.Michael Canavan wrote:The ME is still there in Performer Lite, just as a sub window. I doubt they would limit us to that in DP10 when these changes happen in an update? wouldn't make any sense.
What we can surmise from Performer Lite
Re: What we can surmise from Performer Lite
I'd say it's confirmation it's not going anywhere, at least for now, cuttime. Thanks mate.cuttime wrote:Not sure if this is exactly a confirmation, but the TO resizing bug was confirmed by MOTU, and I was told it would be fixed in an update.
I'd be completely lost without the TO. It's my hub, my rock and my home; trips elsewhere are made on a temporary, as-needed basis, usually via double-clicking MIDI, audio or automation that needs closer inspection or editing.
At least, that's how I rolled many years ago when I last "experimented" with DP. Been living in a theoretical world for a long time now.
- mhschmieder
MM, if you've been living in a theoretical world, does that mean you no longer believe in evolution? Or perhaps you are a living example of devolution? I mean, how many of us have been permanently made into a monkey?
I'm with you on the importance of TO. For me it is the centerpiece of DP.monkey man wrote:I'd say it's confirmation it's not going anywhere, at least for now, cuttime. Thanks mate.cuttime wrote:Not sure if this is exactly a confirmation, but the TO resizing bug was confirmed by MOTU, and I was told it would be fixed in an update.
Me too!billf wrote:I'm with you on the importance of TO. For me it is the centerpiece of DP.monkey man wrote:I'd say it's confirmation it's not going anywhere, at least for now, cuttime. Thanks mate.cuttime wrote:Not sure if this is exactly a confirmation, but the TO resizing bug was confirmed by MOTU, and I was told it would be fixed in an update.
As far as "What we can surmise from Performer Lite" it's all speculation. Features from a [presumably] ground up coded app could be simply implemented into a legacy app like DP is speculation at best.
Ah padawan, there is a guaranteed zero percent chance that Performer Lite is coded from the ground up. It's obviously a cut down version of DP10, including a few features tech support mentioned to me when DP10 came out, like Clips in the Sequence Editor. Why do I say zero percent? because it took over 30 years to get DP10 to the place it is now, it's the Taj Mahal, not a cookie cutter suburban home. Things are missing from Performer Lite, but the basics are all there. Again no big mystery that a cut down version of a huge complex code base will be easier to debug and might get new features out the door first when it's introduced.MIDI Life Crisis wrote:As far as "What we can surmise from Performer Lite" it's all speculation. Features from a [presumably] ground up coded app could be simply implemented into a legacy app like DP is speculation at best.
There's plenty of precendent for this. Even Garageband, that at first looked completely different than Logic was a stripped down version of Logic underneath, that got a few "new" features (Apple Loop support) before Logic did when it was first introduced. It's not speculation to say that DP10 will soon get Clips in the Sequence Editor, it's flat rational thinking.
What is speculation not worth worrying about is if DP10 will only be 4 edit windows too. That wouldn't make any sense and I'm 100% certain that isn't happening. There isn't one good reason why MOTU's flagship DAW would get something like Tracks removed that helps end users.
I know as much about coding as I do about what the winning lottery numbers will be this evening. If you have any inside info on THAT you'd be rewarded mightily...
big difference between having inside info on how development works and being able to code.MIDI Life Crisis wrote:I know as much about coding as I do about what the winning lottery numbers will be this evening. If you have any inside info on THAT you'd be rewarded mightily...
I'm 100% certain that DP10 gets Clips in the Sequence Editor, and that Performer Lite is a stripped down version of DP10.
What I can't tell you and you're 100% right on is when DP10 gets these things. The more complex daddy code base is going to be harder to debug, more variables equal more possibilities for error. It's possible that areas that are not in Lite are having issues with Clips etc.? How are they going to implement Clips in the Tracks View for instance? We can see how they're going to do it in the Sequence Editor.
Well, stubbsonic just got an M4. Why don't we just ask him?
Excellent!cuttime wrote:Well, stubbsonic just got an M4. Why don't we just ask him?
You're assuming I did, Mark.mhschmieder wrote:MM, if you've been living in a theoretical world, does that mean you no longer believe in evolution?
This I can attest to. The ol' laws of entropy have ensured my steady demise from what was already a very-low base, I'm afraid.mhschmieder wrote:Or perhaps you are a living example of devolution?
Only one that I'm certain of, Mark... and there's that gorilla too of course.mhschmieder wrote:I mean, how many of us have been permanently made into a monkey?
Hey guys, great to see all the love for the TO. May it never die!
- terrybritton
- Primary DAW OS: Windows
Knock knockmonkey man wrote:Only one that I'm certain of, Mark... and there's that gorilla too of course.mhschmieder wrote:I mean, how many of us have been permanently made into a monkey?
Who's there?
Gorilla
Gorilla who?
Gorilla my dreams.
THAT'S what I think I can surmise from Performer Lite!
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
Performer Lite Manual -
https://motu.com/techsupport/manuals
So far a new "Hand" Tool is also present in Performer Lite.
No mention of MPE.
No Tracks, Song, Waveform windows.
A new record mode allows you to record Clips into the Sequence Editor or to record directly into a clip.HAND TOOL
The Hand tool allows you to scroll
graphic editors smoothly and precisely. It
also lets you scroll vertically and
horizontally in a single gesture. Simply click
anywhere in the graphic editor grid and drag as
desired.
No mention of MPE.
