A new bug in the latest DP for Split Notes.
When you use Split Notes you can select a target track, under "Send the notes to:", and choose from the menu below that heading, but now it defaults to "One new track."
Formerly, once you selected "One track" (say you chose "Violin 1"), if you repeated the command, it would send the tracks to the same target track -- Violin 1.
Unfortunately, now, when you repeat the command, the selection "One new track" is highlighted in blue (even though the selection button is not checked), with the result that, unless you use the mouse to click on the blue-highlighted track, and then again on "One track" with your target's name in it, DP creates a new track anyway.
It's driving me crazy since I use that command constantly when preparing a score to be exported to Finale or Sibelius.
Anyone know a solution?
Split Notes new problem
- Timeline
Re: Split Notes new problem
Didn't know you could do that
