Vienna Ensemble Pro 7 available now
VE Pro 7 is out. Anyone plan on jumping in early? I have several ongoing large projects that have intimate relationships with VEP6 so it may be a bit before I try it. I’d love to hear any reports from any brave users that give it a go. ...ideally, from VE guru Steve Steele before making the attempt.
https://www.vsl.co.at/en/Software/Vienna_Ensemble_Pro
- mhschmieder
Re: Vienna Ensemble Pro 7 available now
I may be ready to give it a try, as I put the finishing touches on final track review of my jazz album late last night so am interesting in seeing whether Vienna Ensemble will help my workflow as I finally head into the long-overdue mixing stage of this project.
As I have only toyed with Vienna Ensemble over the years and never got around to making it an active part of my workflow or templates, I at least won't have to worry about compatibility with VE Pro 6. But as VE Pro 6 was very unstable and crash-prone in DP, Logic, and Studio One (maybe Cubase as well; I forget), I am hoping that at least that situation has improved with VE Pro 7.
Cool. Let me know if you think it’s worth trying out. I still haven’t seen any really compelling new features that make me want to try it.
Re VE Pro stability. Hmm. I can only recall VEP6 crashing one time for me over several years of heavy use, so increased stability isn’t a factor for me. A decrease is what I’m hoping to avoid. ...ironically that crash occurred when I tried to instantiate the new Vienna Synchron instrument into an existing template.
- mhschmieder
Due to DP having the best plug-in manager in the industry, by a factor of at least ten, it is sometimes hard to know what would be a problem in DP for a plug-in one isn't actively using all the time. I think the VE Pro issues with DP were fixed a while back.
It's the other DAW's where instability of plug-in validation at the DAW level and especially within VE Pro -- which does its own plug-in hosting validation -- never seemed to get into shape (especially for Studio One, which I use ironically almost exclusively for quarantining new plug-ins to deem safe for use in critical-path DP projects or not).
There a whole lotta posts on VI-Control about this, including several about plugin validation. It looks like 7 is more discriminating than 6, which may address some of what you’re referring to. No posts yet about the MAS version that I see.
https://vi-control.net/community/thread ... 97/page-22
guys, I'm going to follow your progress carefully, as I'm just get back to VEPro after a 3-4 year absense. So, I've already downloaded and installed VEPro7, but there are a couple of concerns right off teh bat. Perhaps you all could offer thgouhts?
(1.) I couldn't actually open VEPro7, as it couldn't find a license on eLicenser, as eLicenser couldn't find a valid license, cause blah, blah, blah....whatever, I'll sort this one out with VSL
(2.) when I tried to open an isntance of VEPro7 stereo in a DP file, it told me to go off and read the "Important Notes for Digital Performer Users" in the VEPro7 manual....
o.k., did that. but I noted that the first section of the "Important notes....blah, blah" page is all about setting DP for "All Plugins in Real Time"...isn't that a non-issue after DP9?
(3.) next thing I read on the "Important notes....blah, blah" page, is teh comment "Bouncing (offline rendering) does not work when using Audio Unit Event Input ot Audio Input plugins..." and I'm begining to think, "...maybe *this* is why I bailed on VEPro 3-4 years ago? I use Bounce - not Freeze - *all* the time - - couldn't work without it. So will I no longer be able to "Bounce" MIDI -> audio with VEPro7?
hmmm....
hmmm....
Kurz Midiboard, MOTU MTP AV
https://vimeo.com/71580152
~me
~me
- bralston
Willie,
1. If you are using VEPro in DP you will 100% want to be using the MAS version. I would even go into the DP plug-in preferences window and just uncheck the installed AU and VST versions of VEPro for DP to be sure. The MAS version can handle multiple MIDI ports (48 with 16 channels each) in just one VEPro instance....AU version 2 spec by design is one MIDI port with 16 channels only. AU version 3 spec opens more MIDI ports but that is in Beta and not really solid yet. When using the MAS version....no Event input is needed like the old days before Vienna did MAS version to get other MIDI ports or anything....it works as designed and intended. AND.....Off-line bounce works just fine with the MAS version.
2. DP9 and now DP10 with their "next gen-pregen" rendering in the back ground do not work with an outside the program host like VEPro. VIs have to be hosted in DP for that to work. As a result...VEPro always runs in real time in DP. That is likely what that is referring to.
3. As for you eLicenser....you need to make sure you are running the latest eLicenser software from Steinberg...and also be sure you have taken your authorization code in your MyVSL account for VEPro7 and added it to your USB Steinberg Key dongle for VEPro7....or if you are not using a USB Steinberg key...to the eLicenser soft-key on your system through eLicenser.
Regards,
Brian Ralston
Brian Ralston
I will definitely need a bunch of input as to what VEP7 gives that 6 doesnt have. 6 is superb here in the MAS version.
Very confused so far with 7s offerings.
Yes. Me too. Since VEP 6 is basically flawless for me, I'm in no hurry. I'll need to see some pretty compelling reasons to switch.labman wrote:I will definitely need a bunch of input as to what VEP7 gives that 6 doesnt have. 6 is superb here in the MAS version.
There's a ton of functionality in VE I don't need or use. I think a lot of the new features may be for VE power-users.
The YouTube page of Steve Steele, who I mentioned in the OP, says a VE Pro 7 with Kontakt 6 How-to is in the works. I'll definitely wait until I see that before I upgrade. ...along with some help from MN users, I based my VE workflow on his videos.
- toodamnhip
Ah yes, the Ol' "point zero" dive! I'm a shakn' like a lil' boy at the neighborhood swimming pool 1st day of summer...Cant jump, can't jump in......dix wrote:VE Pro 7 is out. Anyone plan on jumping in early? I have several ongoing large projects that have intimate relationships with VEP6 so it may be a bit before I try it. I’d love to hear any reports from any brave users that give it a go. ...ideally, from VE guru Steve Steele before making the attempt.
Mac Pro (Late 2013
2.7 GHz 12-Core Intel Xeon E5
64 GB 1866 MHz DDR3
Mojave
DP 10.13
MOTU 8pre, MTP AV, 828 mkII
64 GB 1866 MHz DDR3
Mojave
DP 10.13
- ronjams
I just jumped in last night and I'm just trying to wrap my head around all of the various concepts of routing. Why would anyone put themselves through all of this configuring? What is the benefit of this program other than workflow? I'm brand new to this. I stayed up and watched a few Youtube videos. I don't get it yet. What is the purpose of this program? What is the intended result?dix wrote:VE Pro 7 is out. Anyone plan on jumping in early? I have several ongoing large projects that have intimate relationships with VEP6 so it may be a bit before I try it. I’d love to hear any reports from any brave users that give it a go. ...ideally, from VE guru Steve Steele before making the attempt.
Mac Studio M1 Max DIGITAL PERFORMER• 1248/8pre ES • Falcon/kontakt/Unify & A LOT MORE GEAR
- terrybritton
- Primary DAW OS: Windows
Did you see this overview by Steve Steele?ronjams wrote:I just jumped in last night and I'm just trying to wrap my head around all of the various concepts of routing. Why would anyone put themselves through all of this configuring? What is the benefit of this program other than workflow? I'm brand new to this. I stayed up and watched a few Youtube videos. I don't get it yet. What is the purpose of this program? What is the intended result?
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
- terrybritton
BTW - they throw in a 70 gigabyte orchestral library for free with this one, and many feel that alone is worth the price of admission. Plus, the EQ, compressor and other plugins included with VEP7 contain presets tailor-made for specific instruments and ensembles.
Pretty neat. I went for it. This is my first exposure to VEP.
Terry
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
- zuul-studios
I've been using VEPro & DP for a few years. So far, the upgrade to VEPro 7 along with the upgrade to DP10 has proven stable for my needs.
Computer:
Apple's M2 Mac Studio with 96 RAM; macOS X 14.5 (beta 3); 1 Internal SSD, 8 External SSDs, MOTU 828es audio device, AKAI MPK88 Keyboard Controller
Software:
DP11.31, Logic Pro X, FCPX, DaVinci Resolve; VSL's Super Package, VEPro 7 & MIR Pro, VI Pro 2; Altiverb 8; Cinesample's CineSympnony Complete Bundle; Native-Instrument's Komplete 13 Ultimate Collectors Edition, and many more VIs.
Software:
