USB Fastlane issue
Posted: Sat Oct 13, 2018 7:22 pm
I sent this to the motu-mac group as well.
Thought I could get some more eyes if I posted it here too.
Hi all.
Just wondering if anyone still uses a fastlane usb in yosemite (or above)? Mine's pretty old.
I'm having a problem with MIDI in DP 8.07 on Yosemite.
For whatever reason it seems to work in Superior Drummer 3. It's worth noting that I've just started with Superior Drummer (and virtual/MIDI instruments in general), so when I say "works" I'm saying I'm able to use my korg keyboard as a MIDI controller successfully and it's also listed in SD3's "Audio/MIDI Setup" menu. (The fastlane is listed. Not the korg keyboard.)
Screenshot: https://www.dropbox.com/s/2quyf98ikjkug ... M.png?dl=0 )
In DP, however, while in the Tracks Overview, if I attempt to choose a different input/output for a track I'm presented with dropdowns containing text like "Unconfigured Ports" and "IAC (Missing)".
However, you can see that the Fastlane is indeed listed. It's just nested badly??
It's listed as a child of "Unconfigured Ports" and that can't be a good thing.
But why is SD3 seeming to see it?
I've downloaded and installed the newest driver from MOTU's site as well as had one sent via an exchange with a MOTU tech. (We're still not done with the issue but I thought I'd mention it here as well.) Its filename contains "Installer 1.6 (73220)(4).pkg".
It seems to be installed successfully and after doing so I'm told to restart. After a restart of both computer and DP opening up DP, however, nothing changes. Same thing.
Here it is in "About this mac -> System Report -> USB":
https://www.dropbox.com/s/bwychou2obq2d ... M.png?dl=0
I also use a MIO2882+DSP FWIW.
Thanks for any advice!
Hi all.
