Hi.
I'm using DP8 windows version on a win7 pc. I'm working with MIDI tracks imported to DP8 and using a Motif XF8 as a tone generator for this project.
In the tracks window I accidentally selected a patch number which I am trying to clear and cannot find any way to do it. I see the 'clear default patch' in the mini menu, but this does not clear the patch selection in DP8. I don't see anything related to this in the manual and I can't find a way to clear that field to a blank default. Checked the Event List and don't see any patch selection there to delete.
I'm embarrassed to ask such a fundamental question, but I can't find a solution. Would anyone have any suggestions to share?
Thanks.
How to Clear Patch in Tracks Window
- FMiguelez
Re: How to Clear Patch in Tracks Window
Hmmmm... That Clear Default Patch should've done it. You did select the target track(s) and then applied the command, correct?
