Running on a 1.2 GHz G4 Cube at 10.3.9 yielded many artifacts. When using the reverb, audio performance in DP 4.6 spiked frequently and produced artifacts. When disabling reverb, the processor spikes went away but the same artifacts were there. In 10.3.0 the artifacts were gone for the most part unless reverb was used. In 10.4 there were no artifacts unless reverb was enabled.
Now I'm using the default buffer settings in DP which have worked very well, even with several Renaissance Reverb plugs active. It would be nice to not have to make a huge DAW adjustment for MSI. At this point I'll have to record dry and up the buffers hugely to enable reverb and bounce one track to disk at a time.
I really hope MOTU refines the CPU usage of this otherwise very nice product. That's all I got to say about that.
Mixed results with CPU usage and artifacts
Artifacts are very bad on 10.3.9
On Mac OS X 10.3.9 the artifacts are really bad. It sounds like the samples are 64k MP3 files. Does anyone know how to get rifd of them?
Re: Artifacts are very bad on 10.3.9
http://www.unicornation.com/phpBB2/viewtopic.php?t=6525filmscore05 wrote:On Mac OS X 10.3.9 the artifacts are really bad. It sounds like the samples are 64k MP3 files. Does anyone know how to get rifd of them?
