MX4 mod wheel (filter automation)
Posted: Fri Feb 23, 2018 8:51 am
by ec_pat5150
Hello everyone! I've recently started using Digitai Performer to make electronic music, and i'm seeking some help with MX4.
How do i make automated filter effects with MX4? Forgive me if my terminology is incorrect, but it's that beloved "build up" effect on synths that is used by lots of famous dudes.
Re: MX4 mod wheel (filter automation)
Posted: Fri Feb 23, 2018 7:44 pm
by cuttime
R-click on the parameter you want and select "Learn Controller Mapping". Use your controller of choice and MX4 will follow along.
Posted: Sun Sep 01, 2019 5:26 pm
by KenNickels
cuttime wrote:R-click on the parameter you want and select "Learn Controller Mapping". Use your controller of choice and MX4 will follow along.
Great! I didn't know that could be done.
Posted: Sun Sep 01, 2019 10:22 pm
by cuttime
KenNickels wrote:cuttime wrote:R-click on the parameter you want and select "Learn Controller Mapping". Use your controller of choice and MX4 will follow along.
This is sorta kinda standard procedure with a lot of plugs. Along with the "Enable Learn Mode" (keyboard icon in the DP plug window), it usually gets the job done.
