[SOLVED] DP9 and TouchOSC
Posted: Sat Dec 09, 2017 1:16 am
Hey there,
was anybody able to get TouchOSC to work with DP on win 10?
If I set OSC under Control Surface setup, I only see an input port, but no output, and I cannot find something in DP to validate that is receives the Messages I'm sending.
The PC receives OSC messages, so that *per se* works. MIDI-Messages and Keyboard Shortcuts through TouchOSC Bridge work as well - I just can't see anywhere if DP is receiving the mesages, and where it outputs them?
Any help is appreciated
Edit [SOLVED]:
It seems like TouchOSC does not support the way Motu implemented OSC in DP (multiple parameters). If the contrary is true, I only have found un-answered forum posts about that on the hexler forum, I mark it as solved, but still, if I'm wrong, please correct me.
Edit [SOLVED]:
