Lost the Sequence List Window
lampfilmusic
Post by lampfilmusic »
Daft question, but just can't find it.
When using DP years ago, I used to be able to call up a Sequences window, that listed ...sequences one on top of the other, and it was possible to set a SMPTE start time for each sequence.
Now, I can't find that window anywhere. I have found the Chunks window, which I can use to do the same thing - set a different SMPTE start time for each, but is there still a way to access the old Sequences window?
Thanks in advance for your help! :?
Re: Lost the Sequence List Window
I started using DP 5 after a trial with V4, and I've never heard of the Sequence Window. I do remember jokes at the time, that DP has hundred of windows, one for everything. Maybe it was renamed Chunks when V-Racks were added.
lampfilmusic
Thanks Bayswater.
Yes, the Chunks window is where the sequences are listed, and where you an manually assign a SMPTE start time to the selected chunk (if it is a sequence or song)
lampfilmusic
Cheers stubbsonic! :)
