Micro Express + Micro Lite
Posted: Tue Sep 26, 2017 5:30 pm
by dilznik
The Micro Express can be used standalone. The Micro Lite needs a Mac or PC to work. HOWEVER, if you have the Micro Express as the main MIDI interface, can you then plug in a Micro Lite without a computer and have it work as an expansion?
Re: Micro Express + Micro Lite
Posted: Wed Sep 27, 2017 5:32 am
by terrybritton
dilznik wrote:The Micro Express can be used standalone. The Micro Lite needs a Mac or PC to work. HOWEVER, if you have the Micro Express as the main MIDI interface, can you then plug in a Micro Lite without a computer and have it work as an expansion?
Where would it get its power from? I believe both units are powered via the USB bus. (No power is sent over MIDI cables, if that's what you meant.)
Are you talking about an older, pre-USB version of the Micro Express like found here at Reverb.com? That has no USB bus to power the other, so the answer would remain no.
https://reverb.com/item/4593447-the-ori ... ntage-unit
Terry
Posted: Wed Sep 27, 2017 1:28 pm
by mikehalloran
Yes, that requires a Beige G3 or older Mac. Windows is compatible up to XP with the right cable.
$50? I got $65 plus shipping on eBay last year for mine. Worked perfectly.
