Weird bundles issue
Posted: Sat Jun 17, 2017 4:24 am
I was cutting some guitar leads in stereo from my Kemper amp and kept having this same weird issue where Ch 1 left was always behind Ch 2 by about 1145 samples or around 26 ms - obviously quite audible. I was using channels 1 and 2 of my Midas M32R which I normally use for kick and snare (as mono channels) so I thought something was set wrong at the board on Ch 1. Switching to Ch 3-4 worked perfectly. Back to Ch 1-2 same issue. Finally after much ado and head scratching I turned to DP and then Bundles. Ch 1 and 2 were at the top of the bundles list as 2 mono channels, the way I use them most of the time for kick and snare. At the bottom of the list was Ch 1-2 as a stereo pair. I deleted the mono ones and the problem was instantly fixed. Not sure if this is a bug or just one of those one-time glitches. I just switched from DP 8.07 to 9.12 so I'm not sure if that's related, but t might be as this file was created in 8.07. Has anyone here run into anything like this?
