DP 9.13 available
sdfalk
Re: DP{ 9.13 available
Post by sdfalk »
James Steele wrote:
David Polich wrote:So...the improved pitch and time stretching algorighthm
is definitely NOT in 9.13?
Yes. Not in there. According to the demo that MOTU gave at the booth there will be a little drop down menu that you choose the time of algorithm and it is not there. Plus I have a source a MOTU that confirmed it will be in the next version.
If you don't mind me asking , was your source referring to the next major version (10) or A point
update.
Or was that revealed to you.
A Metric Halo ULN8-3D…mmmmmmm
Re: DP 9.13 available
If they demoed it at NAMM in January, I don't think it's that far off. It's just speculation. I now nothing about what version it would be either.
sdfalk
Post by sdfalk »
James Steele wrote:If they demoed it at NAMM in January, I don't think it's that far off. It's just speculation. I now nothing about what version it would be either.
Fair enough..
thanks for the quick reply
Svanzini
Post by Svanzini »
Installed 9.3 Works fine but had several crashes when adding Fades in Edited Soundbites.
Mac Pro (Late 2013),MacOs Sierra Version 10.12.4, Audio Interface: Motu 1248 Thunderbolt, Motu 896MK3 Optical conection
bleach30
Post by bleach30 »
MIDI Life Crisis wrote:
bleach30 wrote:I would like the run all plugins in real time check box back. It would be nice to have an option and possibly get around some of these other issues.
I just installed 9.13 and it didn't fix any of the issues I am having..such as extremely sluggish/laggey and stuttery behavior when zoomed in to edit and the bigger one of NOT being able to save plugin presets from MOTU's OWN plugins. 3rd party plugins preset saving works fine. This is on my home machine and Im about to go to the studio and see what happens there. On that machine currently I can't save ANY plugin presets.
Can you post you system info? Re: zooming in, you're likely stressing out the CPU. That will also happen with "too many" windows open. "Too many" being defined largely by CPU speed/configuration and RAM amount.
My specs are:
iMac (Retina 5K, 27-inch Late 2015)
3.2 GHZ i5
32 GB ram
10.116
The studio computer is the exact same except the OS. That one is Sierra.
The laggy behavior I have with zooming is an issue with as little as 10 audio tracks with zero plugins or windows open...just straight imported audio. The buffer size or sample rate does not seem to have an affect on this either and there are no background processes happening.
jresende
Post by jresende »
Update to 9.13.Everything is working fine!! No problem here.
Regards
Jota Resende
Brazilian Musician (Piano & Keyboards),Producer and Arranger.
https://www.facebook.com/jota.resende
bleach30 wrote:The buffer size or sample rate does not seem to have an affect on this either and there are no background processes happening.
What buffer sizes are you running on tracking / mixdown?
Something is certainly going on. What happens in Console.app?
Phil O
Post by Phil O »
Weird graphics bug in drum editor. Placing a loop works fine, but the little loop graphic is in the wrong measure. It appears fine in the MIDI editor and sequence editor windows. Went back and checked 9.12 and 9.02. Looks fine in 9.02 but apparently it was introduced in 9.1 and I never noticed it. Still there in 9.13.
Phil
RROY
Post by RROY »
Has it been confirmed that DP 9.13 will not work on Mountain Lion? Has anyone with 10.8.5 got it working?
Mac Pro 2x2.4 quad core /24 gb ram/OS 10.13.6, Dp 10.13, MTP AV, /UAD 2, KOMPLETE 12, Stylus RMX, SD 3.0, EZ Drummer 3, A&H ZED R 16.
corbo-billy
Post by corbo-billy »
RROY wrote:Has it been confirmed that DP 9.13 will not work on Mountain Lion? Has anyone with 10.8.5 got it working?
I know someone in your case but it is not registered on this site. :oops:
So I can only confirm .
Imac M1 24" under Monterey 12.7 & Kontakt 7.6. _ Fireface800 X 2 _ FilterBank2 Sherman & Gibson Explorer Pro _ MIDI Express XT _ Virus C Desktop _ Adrenalinn III & Voyager Moog _ SpeakerPhone 2 _ PolyEvolver Keyboard _ Tempest _ D.P. 11.22 _
It's supported: Mac OS X version 10.6.8 or later
http://motu.com/products/software/dp/specs.html
labman
Post by labman »
Phil O wrote:Weird graphics bug in drum editor. Placing a loop works fine, but the little loop graphic is in the wrong measure. It appears fine in the MIDI editor and sequence editor windows. Went back and checked 9.12 and 9.02. Looks fine in 9.02 but apparently it was introduced in 9.1 and I never noticed it. Still there in 9.13.
Phil
Clear back pre DP9 the drum editor has had serious woes with groove quantize. Anyone know if they have been fixed?
bleach30
Post by bleach30 »
You're right something is going on and has been since 9 for me anyway.
Buffer sizes I've tried are all of them 128-1056 on tracking and mix and in a blank session just importing a few audio files..all the same sample rate.. This was happening before I got my interface and was using just built-in out from my iMac.
This is irritating but I can deal with it but the not being able to save plugin presets is just crazy
JSmith1234567
Post by JSmith1234567 »
Can someone confirm that they have NOT brought back the global preference to run all plug-ins in real-time?
This is the reason I went back to 9.02 after terrible performance and annoyances in 9.12.
Michael Canavan
Post by Michael Canavan »
bleach30 wrote: and the bigger one of NOT being able to save plugin presets from MOTU's OWN plugins. 3rd party plugins preset saving works fine. This is on my home machine and Im about to go to the studio and see what happens there. On that machine currently I can't save ANY plugin presets.
This sounds like Permissions issues to me. Just wondering if you've tried anything on that line?
I've had issues where the OS doesn't allow an application access to my VST and Component folders, or other folders etc.
