MacBook Pro Loses Track of Interface when Sleeping
Hey folks,
Here's what is happening to me: I have two interfaces that I switch between: an Apogee Symphony I/O (my goto) and a Focusrite Sapphire. When my MacBook Pro (late 2011, running El Cap) goes to sleep and then wakes up. It won't work for whichever interface it's using, most but not all of the time.
The interface is on, the MacBook Pro can see it. The Configure Hardware Driver shows the interface is active, and the Sound settings in the Mac shows the interface is active, but no dice. My only surefire cure is to Restart the Mac.
My questions are:
1) Is there a way I can prevent this from happening when the device wakes from sleep?
2) When it does happen, is there a simpler fix than Restarting the Mac?
Thanks in advance,
-Todzilla
My questions are:
Thanks in advance,
-Todzilla
-Todzilla
Huge sound generation & capture facilities
On the banks of the River Eno
__________________________________________________
DP 8!!!, OSX 10.7.3, 15" MacBook Pro w 16G RAM 256G SSD & 630GHD, MOTU 896HD, MX4, Komplete 8, Apogee Symphony I/O, Neumann U-89, pair of Peluso P12s, Seventh Circle & Demeter preamps, Lava lamp, stuffed frog playing bongos
Re: MacBook Pro Loses Track of Interface when Sleeping
I NEVER sleep my machines. N-E-V-E-R-!
That's my solution. I've been doing it for years and it works. I do shut down if i'm not going to be working for extended periods (a couple of hours or more) but NEVER sleep.
Did I mention NEVER SLEEP?
(I thought so)
(I thought so)
- daniel.sneed
As MLC said, for years, it's been a common practice (and sense) to not let a daw setup go to sleep.
Only boot and shut down completely.
More on that subject:
Keep an eye on menumeters memory display (a free app).
Whenever available memory goes short, then close the daw app and relaunch.
Of course, same applies on non-daw apps.
dAn Shakin' all over!
- Gravity Jim
This. Sleep is death. Don't do it.MIDI Life Crisis wrote:I NEVER sleep my machines. N-E-V-E-R-!
Jim Bordner
Yikes!
My DAW is my multi-purpose MBP, so the sleep feature helps for non-DAW purposes. I will experiment with sleeplessness (insomnia?) when the device is plugged in to charger.
-Todzilla
What MLC said.
USB is bad. FireWire is worse.
