My Orchestral Mixes Sound Two Dimensional
- KenNickels
I'm using Proverb on the mix buss from sends on the audio tracks. But man, I must be missing some basic methodology for putting the instruments in a believable space. Most everything I hear sounds ten times better than mine. I am hoping you can advise me here. Help!
My Box(s): Two Mac Pros 5,1/3Ghz, 12 core, 96GB Ram, OS 10.14.6, One Windows 10 computer, Vienna Ensemble Pro, MOTU Audio Express, DP 10.01, Falcon 3, Eastwest, NOVO Strings, 8Dio Brass, Spitfire,, Symphobia
- Gravity Jim
Re: My Orchestral Mixes Sound Two Dimensional
My first questions would be:
What monitors are you mixing with?
Are you using the East/West orchestral VIs?
Jim Bordner
How many instances of your VIs are you running?
Are you using reverb on the mix only? individual instruments? groups?
- KenNickels
Thanks for the reply. I had forgotten this post ...
I have several issues against me, I know. I use Behringer two way 8" speakers. They are not that great. The room is square-ish without much acoustic treatment to speak of. I've taken to EQ-ing minimally, because the more EQ the worse it sounds, and most everything sounds good out of the box (EW Hollywood strings, for example.) Five Plays, 1 Kontakt. I have some hearing loss, so I'm probably mixing with louder highs than I should. Lately I've been mixing with Sennheiser phones because of all this.
I try to get a good balance where I can hear all the parts in relation to each other, using basically using the modwheel for brightness and CC11 for volume. I'd like to know what a more experienced VI orchestral mixer does and doesn't do, regarding getting that open natural breathing space.
Reverb can be used to create depth in a mix back to front just as pan pots can be used to set R/L. I am talking small amounts on your instruments and/or groups.
Remove any reverb from your Master buss for now.
Brass is generally in the back unless you have a large choir behind. Apply just enough to hear it. Apply half that to the woodwinds. Don't apply any to the violins and violas, a small amount to the celli and a little less to the double-basses than the brass. If there is a choir, double the amount you used on the brass. Soloists should have no reverb but, if present, add a little bit to the fiddles to place them back in the mix.
I am not saying what to use here but it should have a fairly short tail and not be too bright or dark — I use a small hall setting for this.
Assuming that you have panned things properly, there should now be a 3-D aspect to your mix that was missing before.
Only when you have this sounding the way you want, should you add a Master reverb for general ambience. This will flatten your mix a bit so you can remove it and tweak the settings to compensate if you like. Now try again.
I generally add too much, wait a day, listen with fresh ears and dial it back some. YMMV.
Yes, you should have better monitors but I'll leave that alone for now.
- KenNickels
I understand what you're saying, but wouldn't sends accomplish the amount of reverb going to each instrument? What is different?
It's the amounts you apply in the various layers that give you depth. How you add it isn't that important.KenNickels wrote:I understand what you're saying, but wouldn't sends accomplish the amount of reverb going to each instrument? What is different?
You can play with the amounts to move a layer front to back in your mix.
Choir - most
Brass - noticeable
Double-basses - less than brass but not 1/2
Winds - 1/2 brass
Celli - a little less than the winds
Fiddles - none unless there are soloists, then add a little
Soloists - none
Once you have your depth, add reverb to the master for ambience. Use your soloist or violins to gauge how much.
- KenNickels
Thanks Mike. In any case, I've been adding too much reverb. I'll keep your guidlines in mind when I mix next time.
- terrybritton
- Primary DAW OS: Windows
Thanks, Mike - nice guidelines to have on a card pinned somewhere in the studio! I've put it in my Evernote for now.mikehalloran wrote:It's the amounts you apply in the various layers that give you depth. How you add it isn't that important.KenNickels wrote:I understand what you're saying, but wouldn't sends accomplish the amount of reverb going to each instrument? What is different?
Choir - most
Brass - noticeable
Winds - 1/2 brass
Soloists - none
Terry
MOTU 828 mk3 hybrid
MOTU 828 mk3 hybrid
- KenNickels
Mike, what kind of speakers would you recommend?
- daniel.sneed
Go figure: I always set too much reverb to get some space and dial back later to get some punch...
dAn Shakin' all over!
Good studio monitors known to be accurate that you can trust. This does cover a lot of ground, I admit.KenNickels wrote:Mike, what kind of speakers would you recommend?
I use a pair of Equator D8 with the wedges, a JBL LSR310 sub crossed over at 80Hz and a Radial MC3 passive controller. It's a system I trust at 3'–4'. Street $1,400.
http://www.equatoraudio.com/New-Improve ... r-p/d8.htm
http://www.jblpro.com/www/products/reco ... cL3o9OGOV4
http://www.radialeng.com/mc3.php
That MC3 controller gives me a level of flexibility that most users don't need. I can balance the speaker pairs and sub via trim pots plus I can reverse the polarity of the sub and remove it from the mix, all from the unit — no crawling under my desk to adjust the JBL Most won't need that functionality, frankly as those are also controllable from all active speakers and decent subs.
Equator is of the opinion you don't really need a sub with the D8s — I wouldn't trust them as well without. A number of $399–$1,200 subs work well with these. Ted recommends the KRK 12S, not a bad choice (I prefer the JBL to the KRK 10S but the 10S isn't awful). You can take some subs out of the mix with a footswitch, a very handy feature — missing on the LSR310 but the Radial lets me do that from the desktop.
The Genelec 8050A / 8050B are popular around here. The difference is a special low-power idle mode on the B. The A was discontinued around 2013 but can be sometimes be found used. Street new is $3,800 for the 8050B
So many choices.
- KenNickels
Thank you for those suggestions, Mike. The Equator web site lists those speakers as $749(pr). Not so?
Regarding the sub woofer: Do you use this because you anticipate your audience using them as well? Or to keep you from making bass heavy mixes? I'm curious as to their usage.
Yes!KenNickels wrote:Regarding the sub woofer: Do you use this because you anticipate your audience using them as well? Or to keep you from making bass heavy mixes?
Switching the sub in and out gives two perspectives on a mix, both of which are valuable.
Subs are also a great help in identifying low frequency artifacts one can easily miss without a sub.
So. When they get them back in stock, they may offer a package with the foam wedges and cables — last time the sale price was $699. Being also in California, I pay sales tax.KenNickels wrote:Thank you for those suggestions, Mike. The Equator web site lists those speakers as $749(pr). Not so?
My $1,400 Street includes $399 for the sub + $259 for the Radial MC3. In my case, I had Sweetwater combine the two for a bundle price that saved me money. Sweetwater is a sponsor of this site so, if I can use them, I do.
Lots of good subs out there. Unlike the JBL, the KRK 10S and PreSonus Temblor T10 use a footswitch for bypassing the sub temporarily (included with the T10). The MC3 makes that redundant so it doesnt matter that the JBL doesn’t have that function. All three go for $399.
Lots of controllers on the market. The Mackie Big Knob is discontinued but easy to find used. Mackie has replaced it with a few new models. Get one that sums to Mono by pushing a button — so convienient compared to doing it in software. This lets you find if there are phase anomalies between your channels. Being able to turn your mix up and down with one knob... again, infinitely more convenient than doing it in software. Most will have a -20dB button so that you knock the volume down if someone wants to talk to you while working — convenient. You’ll find lots of recommendations for other active and passive controllers in other threads.
Again, yes to both questions.Regarding the sub woofer: Do you use this because you anticipate your audience using them as well? Or to keep you from making bass heavy mixes? I'm curious as to their usage.
I hear quite clearly down there and I want to know what’s going on.
