Korg nanoKontrol 2 CC Mode
Posted: Fri Jan 20, 2017 6:01 am
by Tama300
Greetings, I have been using my nanoKontrol2 in DP mode, but now I'm trying to use it on CC Mode. The faders and knobs works perfectly but I can`t configure the Transport control. I went into the DP/commands, in the Transport section, to edit the event list and press the physical button on the nanokontrol. End up with something like: #45 | 127.
But, it still does not work ... Anyone know how to set it up correctly?
Re: Korg nanoKontrol 2 CC Mode
Posted: Fri Jan 20, 2017 6:15 am
by Guitar Gaz
I have a NanoKontrol 1 which I use for CC mode (I can assign faders etc and then control V-Rack faders with this) and I use my NanoKontrol 2 in DP mode for all normal mixer faders - but I could never get the NanoKontrol 2 to work in CC mode - so interested how you did that.
On the other hand both have always been able to use the Transport controls although with the NanoKontrol 1 you have to set this up under Commands - but the NanoKontrol 2 in DP mode has always worked the Transport controls - so this is all a bit puzzling. I will have another look tonight when I get a chance.
Posted: Fri Jan 20, 2017 3:01 pm
by Tama300
Hi, to use nanoKontorl2 in CC mode you have to press and hold down the SET MARKER and CYCLE buttons and then connect the USB cable.
Then you are able to configure with the Korg Kontrol Editor.
But I don't know why, DP doesn't recognize my settings for transport buttons.
