Page 1 of 2
Direct Hardware Playthrough
Posted: Tue Jan 17, 2017 11:32 am
by bleach30
Ok so I have an Ultrlite AVB..I'm still getting use to AVB routing browser thingy and I am slowly understanding it but I am getting latency in headphones with record enabled tracks.
This was usually a case (for me anyway) of "Monitor record-enabled tracks through effects" box being selected. So I went to the "Input Monitoring Mode" and in fact that box is selected, however, the one I want to select ,"Direct hardware play through" is greyed out and not selectable.
Is this no longer applicable? If so how do I get the no latency monitoring as I had with my 896mk3?
I'm in DP9.12
Re: Direct Hardware Playthrough
Posted: Tue Jan 17, 2017 1:32 pm
by csavetman
Direct hardware play through is not supported with AVB interfaces. Monitoring through the AVB mixer is how MOTU suggests it be done. There's a thread on here somewhere about this.
Posted: Tue Jan 17, 2017 2:45 pm
by bleach30
hmmm.alrighty thanks. I'll look around for that.
Posted: Wed Jan 18, 2017 8:38 am
by EMRR
Yes, Direct Hardware Playthrough is dead. Very unfortunate.
Posted: Wed Jan 18, 2017 1:15 pm
by Klaus
Get a used 'direct hardware capable' box i.e.896mk3hybrid until Motu reinvents it
Klaus
Posted: Wed Jan 18, 2017 1:51 pm
by James Steele
EMRR wrote:Yes, Direct Hardware Playthrough is dead. Very unfortunate.
Not for me!
I guess that's a good reason to hang on to my PCIe interfaces a bit longer.
Posted: Wed Jan 18, 2017 4:13 pm
by dix
I'll say. With so many great I/Os out there now Direct Hardware Playthrough may be the only thing that would prevent me from going with a non MOTU i/o when I, eventually, move away from a PCIe rig.
Posted: Thu Jan 19, 2017 5:19 am
by bleach30
Well that's a bummer. I thought I had it figured out by monitoring through the internal mixer..but that has no affect. OK then i guess the only way to have low latency is low buffer setting now unless I'm missing something...please tell me I'm missing something.....please
Thanks guys
Posted: Thu Jan 19, 2017 5:24 am
by Saintmatthew
bleach30 wrote:Well that's a bummer. I thought I had it figured out by monitoring through the internal mixer..but that has no affect. OK then i guess the only way to have low latency is low buffer setting now unless I'm missing something...please tell me I'm missing something.....please
Thanks guys
You'll have to monitor through the mixer, and have the record enabled track routed to a "dummy" audio output, one that is connected to an output that isn't being used. That way, you can monitor through the mixer but the slightly delayed signal you get from the record enabled track is messing you up by doubling the signal and blurring it.
Posted: Thu Jan 19, 2017 6:33 am
by csavetman
Saintmatthew wrote:bleach30 wrote:Well that's a bummer. I thought I had it figured out by monitoring through the internal mixer..but that has no affect. OK then i guess the only way to have low latency is low buffer setting now unless I'm missing something...please tell me I'm missing something.....please
Thanks guys
You can just open up the input monitoring dialog box in DP and set it to off, to automatically mute record enabled tracks through DP if monitoring outside the program (through the AVB mixer for example)
Carlos
Posted: Thu Jan 19, 2017 6:47 am
by bleach30
[You can just open up the input monitoring dialog box in DP and set it to off, to automatically mute record enabled tracks through DP if monitoring outside the program (through the AVB mixer for example)]
Yes that works too. I had tried that early on but I had things routed all weird when I was trying to figure this out.
Posted: Thu Jan 19, 2017 7:24 am
by bleach30
Ok all working now. This avb routing thing is not very intuitive , at least for me. Thank you for you tips
Saintmatthew and csavetman!
Posted: Thu Jan 19, 2017 12:20 pm
by dix
Slate just announced an ultra low latency i/o. TB for Macs PCIe for PCs. If they could make the PCIe work with MacPro towers it would be a good "transitional" i/o for people with old MacPros that want/have to eventually move to a TB system. I don't think there's anything else out there that's PCIe and TB.
Posted: Thu Jan 19, 2017 12:27 pm
by buzzsmith
I could be wrong, dix, but in the Slate Audiophiles Facebook group, Steven mentioned that the PCIe is compatible with older MacPros. I posted a question there as a followup since I'm early 2009 with mine.
Posted: Thu Jan 19, 2017 12:37 pm
by dix
That would make sense. The Slate video only mentioned PCs being compatible with the PCIe card, but I bet there's just as large a market for old MPs. Fingers crossed.
