Quick Time Compression?
I am trying to export a half hour movie currently at full broadcast resolution to a quick time movie for DP from an AVID Adrenaline. Does anyone have a recommendation for a compression option?
There are about 20 choices in the menu
Re: Quick Time Compression?
Export it at DV-PAL for Ireland if you want full screen playback on an external monitor via a transcoder like the Canopus ADVC 100.
You can reduce it to a smaller (quarter or half) size from the Avid if you just want to play a QT movie from within DP. In that case, I'd recommend a really efficient codec, like Sorenson, or Photo-JPEG at 50% or so.
Your term "full broadcast resolution" is a loaded one that can mean different things to different people.
<small>[ July 25, 2005, 12:05 PM: Message edited by: Jim ]</small>
recording: Mac Mini 2018 - 32GB RAM - 3.2 GHz 6-Core Intel Core i7 - two Focusrite Scarlett 18i20 - OS 12.7.4 - DP 11.23
mixing: MacPro7,1 - 256GB RAM - 2.7 GHz 24-Core Intel Xeon W - Focusrite Scarlett Solo - OS 12.7.4 - DP 11.23
Both computers: Kontakt Komplete 13 VIs and effects. Effects: FabFilter, Sonnox Oxford, SSL, PSP, UA, iZotope. VIs: Cherry Audio, AIR Tech, GForce, AAS, East-West, Garritan, Best Service, Kilohearts, Brainworx, UA
just be aware that a dv-pal movie will run approx 1gb per 5 minutes of runtime. So you could be looking at a 30gb movie file!!
The adrenaline does come bundled with Sorenson Squeeze so you could get the editor to load it up and use that. Its amazing how much it compresses a movie with very little image degradation.
I often squeeze 10min/2gb files down to 30/40mb and the results are surprisingly good.
"silly keeps you sane"
- BKK-OZ
Get QT Pro 7 & use the H 264 codec. yummy.
Cheers,
BK
- M Kaku
BK
- M Kaku
Well... AFAIK, QT 7 isn't qualified for Avid products yet. It takes Avid about six months to a year to qualify "new" OS and QT flavors.Originally posted by BKK-OZ:
And, if you want the full screen playback on an external monitor via FireWire, DP limits you to certain codecs. RTM for more info.
Thanks for all of the suggestions. I ended up compressing the movie from the Avid Adrenaline using the Quicktime photo-JPEG option and it worked fine. It looks good and runs with no problem in DP. Thanks again - Steve
- BKK-OZ
...sorry, wasn't thinking about Avid or his environment, I defer to your greater knowledge.Originally posted by Jim:
AFAIK, QT 7 isn't qualified for Avid products yet. It takes Avid about six months to a year to qualify "new" OS and QT flavors. [/QB]
generally speaking, that 264 codec is just a dream tho, I'm sure its going to conquer the world in a few months.
Cheers,
BK
- M Kaku
BK
- M Kaku
Sort of on the same topic as this thread...If I want to export my movie from Final Cut Express HD, what format yields the "best quality" for destination to DVD?
PowerMac G4 Dual 867 Mhz/1.25 GB RAM/OS 10.3.8 | PowerBook G4 1.5 Ghz/2.0 GB RAM/OS 10.3.8 |DP4.12/MOTU 828mkII
You want to transcode as few times as possible. So, if you can make your DVDs on the same machine as your iDVD or DVDSP, you can export a QT Reference Movie for compression to MPEG2 in iDVD, Compressor (or another app like BitVice). If you're making the DVD on a different machine, export from FCP using whatever codec your footage is using, so that you don't transcode another time.
On the ongoing subject of Quicktime clips.... I am trying to post (to an FTP server) an 11 minute Quicktime film with my score in it and currently it can take up to two hours to post - and it frequently stalls in the middle of the transmission - requiring baby sitting on my part.
I tried to Dropstuff - but, that didn't work. Is there a solution and/or a suggested compression size for this kind of thing? What about emailing an 11 minute QT file? It needs to be compressed, yes?
Shawn
Shawn
Mac Pro Quad Core, 2.93GHz, OSX Snow Leopard 10.6.2, Digital Performer 7.02, Gigastudios, MTP-AVs, MOTU 208mk3, Kirk Hunter, Jeff Sigurdson Guitars, Universal Audio, Spectrasonics, Sonic Implants, Bogner, Deering Banjos, G-String Ukeleles, Ultra Focus, Mach 5, VSL, Native Instruments, Rode Mics, Sibelius 5, Waves, Line 6, Tom Anderson Guitarworks, Wave Arts, Universal Audio, Mackie HR 824's
You could look into software that'll split and cocentate: That takes a file, and breaks it down into smaller user-definable pieces that can be re-assembled (with the same software) at the other end. There used to be an OSX app called SplitnCocentate (I think.). If you're sending to a PC user, that could be a problem, though.
I think the pro versions of Stuffit let you do this, but they may have another term for it.
Most email providers have a size limit, so emailing an 11-min. video is probably not going to work, unless it's highly compressed.
You didn't mention what the video is for. Perhaps you could reduce the frame size, frame rate, or lower the quality (increase the ratio) of the compression... if it's just for screening or review purposes.
