New SMTPE Plug In
- djwizprod
New SMTPE Plug In
When are we going to get that release of DP with the new SMPTE plug, I NEED that now. Not to mention the other features boasted about, the processing load etc.? In the DP9 press release all these things were promoted, and it specifically said 2nd qtr 2016, that would have been last month, no? Yet still no mention of it?
MacPro8core28GB~OS108.5~DP9.1
PT10~MACH5~Symphonic~Reason~Symphobia~NIKOMPLETE~StormDrum2+3~EWSilver
MiniCore2duo2GB~VirtualVTR~TASCAMDM4800surround~2408MkIII~WAVESBroadcast/Surround360/NPP/VoxRider/GEQ/L316~UAD2DuoPCIe+Satellite~1176/LA2A/PulteqPro/Fairchild/SSLBuss/Lexicon224/Dreamverb
IzotopeRX5/Ozone7/StutterEdit
UA6176~U87~TLM103~AKG414~MKH416~MKH50~DPA4011Apair/COS11D~QuickTime7Pro/FinalCutProX/MackieHR824/624/HRS120~TelosZephyrXstreamISDN~SourceConnectPro
http://www.ozonesound.com
Re: New SMTPE Plug In
What new SMPTE plugin are you referring to?
- djwizprod
Cool! Thanks!
Well, it's here in 9.1:
SMPTE-Z plug-in — The SMPTE-Z plug-in generates Longitudinal Time Code (LTC) while locked to DP’s timeline or while running independently in Freewheel mode. The Stillframe option causes time code to continue to be generated even when DP’s transport is stopped (parked on one frame). Time code can be routed anywhere via the audio track’s output assignment, allowing for accurate time code sync in a wide variety of situations.
- djwizprod
Hmmmm, not in my version 9.01, and I loaded 9.02 on another system, not there either... weird?
No. It's in DP 9.1 released today.djwizprod wrote:Hmmmm, not in my version 9.01, and I loaded 9.02 on another system, not there either... weird?
Download it from MOTU and run the installer. That should be all you need to do. A few reported a hang on installation that was fixed by rebooting before running the installer again. No need to remove the older build nor trash preferences.
Also, note it only works with a mono track.djwizprod wrote:Hmmmm, not in my version 9.01, and I loaded 9.02 on another system, not there either... weird?
- djwizprod
Ahhhhh, duh, thanks! Sorry it was late, I wasn't reading that correctly.
Thanks again!
Thanks again!
Hey, no problem.djwizprod wrote:Ahhhhh, duh, thanks! . . .
BTW, don't leave us hanging as so many of these threads do. Please let us know how it works for you including if there are any issues, you have to contact Support or if it just works as expected.
- djwizprod
Will do! thanks again.
- djwizprod
SMPTE - Z so far so good seems to be PERFECT!mikehalloran wrote:Hey, no problem.djwizprod wrote:Ahhhhh, duh, thanks! . . .
No issues with Download and Install here.
posted this over in the "9.1 is here" thread
DP 9.1 - HOLY ISH! MOTU killing all other NATIVE DAWS
My first real world test is a mix on a pretty big pop song session and my initial impressions are OMG UNBELIEVABLE!!!
I'm running OS 10.8.5 on a Mac Pro 8 Core (2 x 2.4Ghz Quad Core) Intel Xeon system with 28 GB 1056 mHz DDR3 RAM. OS and Apps running off a Western Digital 7200 RPM drive, and DP Projects running off a second Western Digital 10,000 RPM drive. Dual 1600 x 900 Acer monitors running on ATI Radeon HD 5770 1024MB. MOTU 2408 MKIII 24 channels ADAT i/o to Tascam DM 4800 mixer. UAD-2 DUO PCI and UAD-2 Satellite FW 800.
Now for the AMAZING session deets! 12 Stereo busses, 88 tracks of audio, 48kHz 24bit, running a buffer setting of 128 SERIOUSLY. Automation of volume, pan, and buss sends on nearly every track, as well as some plug in automation. Speaking of plug ins... here's the list of Native plugs instances (all plugs running AU format)...
- MOTU -
01 - Delay
08 - Para EQ2
01 - Echo
05 - Trim
01 - MstrWks EQ
- WAVES -
07 - L3 LL Multi
10 - Ren Compressor
03 - C1 Gate
- IZOTOPE -
01 - Ozone 7 Imager
- NATIVE INSTRUMENTS -
03 - Transient Designer
Now for the UAD plugs...
02 - Dreamverb
14 - Cambridge EQ
02 - RS1 Reverb
11 - Legacy 1176LN Compressor
13 - Legacy Pulteq Pro EQ
07 - Legacy LA-2A Compressor
02 - Lexicon 224 Reverb
01 - Legacy Fairchild
THE RESULT? NO GLITCHES! Processor Meter running about 50% with spikes up to 75%, absolutely ZERO overload processor spikes, previous to 9.1 this session would spike overload with a 512 buffer simply on playback. I'm now instantly jumping around the session at a 128 Buffer with no issues!
I've yet to test complex editing / recording at this buffer, but I'm really impressed so far!
I think that you can mark this thread, Solved.djwizprod wrote:SMPTE - Z so far so good seems to be PERFECT!mikehalloran wrote:Hey, no problem.djwizprod wrote:Ahhhhh, duh, thanks! . . .
It would be great if it could also chase timecode, instead of just generate it.
- djwizprod
DP can chase time code since it was PerformerJSmith1234567 wrote:It would be great if it could also chase timecode, instead of just generate it.
