Plugin Presets not showing (Lexicon PCM)
Just installed Lexicon PCM Native Bundle Plugins. They work fine in DP 902, Win10, but no preset names are visible in the plugin menue. Neither category names nor preset names are displayed. The presets seem to exist though: It's possible to click the empty cells which changes the parameters in the plugin. Anyone else with this problem? What to do?
DP 902, Win 10, i7 8cores, 128 GB RAM.
Re: Plugin Presets not showing (Lexicon PCM)
Dumb question maybe, but you're referring to the plugin's own menu and not the host's (DP-provided) one top-left of the plain window?
DP's preset menu should be empty unless you've specifically saved settings via that route, in which case they're stored separately in a different location from Lex's chosen path, FWIMBW.
Thanks monkey man, yes, I am referring to the plugin's own menu and not the host's. I now have placed a support request at MOTU and hope they will help.
