Ableton Master, DP 9 Slave
foorere
Post by foorere »
Hello.
Is it possible to connect DP to Live as a slave?
I need some detailed instructions if it is possible.
I need ONLY to sync MIDI (not audio).
Thank you.
(I have learned English in 35 days, please have understanding ...)
Guitar Gaz
Re: Ableton Master, DP 9 Slave
Post by Guitar Gaz »
Rewire - DP loads first then you open Live and Rewire works. Don't think it works the other way round.
Gary Shepherd
____________
foorere
Post by foorere »
Thank you.
But how-to-rewire?
I cannot orientate myself inside of DP. I can't find way in Live to have MIDI OUT to DP, neither MIDI IN from Live inside of DP.
Any link to a tutorial is highly appreciated. Thank you a lot.
Start here:
https://www.ableton.com/en/help/article ... ve-rewire/
There are YouTube video tutorials, also.
foorere
Post by foorere »
Thanks Mike.
I have read it but there is no tutorial for Digital Performer. And many tutorials I have found are opposite direction, DP is Master not Slave.
philbrown
Post by philbrown »
Instead of using Rewire, you can set Ableton to send MIDI sync via the IAC bus and then set DP to slave to the IAC bus. Honestly, I've done a lot of sync'ing this to that over the years but I always found the Ableton-DP connection to be problematic as far as timing. I never really solved the issue, but hopefully you'll have better luck than I did.
