I think most of it will be straightforward. There will be bugs. Most people know one when they see one, unless we get too bogged down on whether it's a design flaw, a coding error, poorly implemented features, a GUI glitch, an inefficiency, etc.Robert Randolph wrote:After some more thought.. I think the clear divide between these two things is as such:Phil O wrote:But then again, it's an easy source of confusion if you don't know what MOTU intended. Is the manual wrong or is the program not performing correctly? Does that make sense?
Phil
Manual errata: documentation that differs from how DP has always worked, or how features are marketed.
DP bug: behaviour that differs from documentation that does not fall under 'manual errata status'.
If the documentation appears to be incorrect and the behaviour seems wrong, then I think it's safe to classify it as a bug. If DP behaves how it always has or as advertised, then it's clearly manual errata.
Does that seem like a reasonable distinction between the two possibilities?
(fwiw, I don't plan on adding any of this complex language to the new post should I do it. I will try to explain things as simply and concisely as possible)
And there are errors in the manual, and most will be typos, bad references, missing or incorrect figures, etc. Again, we'll know one when we see it.
To answer your question, Robert, the last time I tagged them, there were about 150 errata, most of them trivial typos that cause little confusion. Maybe 35-40 that could mislead a new user, and maybe 20 or so that leave you wondering What the heck? I haven't checked for some time whether these have been corrected in the V9 manual. With V9 releases. there were instance where the manual did not appear to be updated.
And now the manual is a PDF, there are bugs in the manual. Links and figures sometimes don't appear or work. I guess we can call these manual errata.
